Old 06-19-2007, 03:24 PM   #1
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Wiring
As you can see from the picture my truck has the cab lights on top. I was wondering if anyone knew of any kind of wiring harnesses or anything I could buy to rewire them to work? Also on my gauge cluster my speedo works, and so does my fuel gauge but nothing else does...no battery, no water temp or oil pressure. I was wondering if anyone knew how to fix that cause i'm a dummy when it comes to electrical anything
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 06-19-2007, 05:27 PM   #2
Luvlegs
Luvlegs's Avatar
Re: Wiring
Check the FAQ section - there are schematics there that shows most of the wiring for the trucks. From the Home page, open the FAQs and then look for the one that is a "list" of the FAQ links compiled. You'll find the diagrams in there. Searching on here, you'll find A TON of stuff.
As for the roof lights, are you sure it's the wiring that's bad or are there fuse issues, unhooked connections, switches, etc.?? Kinda hard to help with a vague description.
The diagrams will also help you trace out what you should have and where wires should be "connected".
There is a ton of knowledge on here and without a doubt, someone will be able to point you in the right direction. Do some searches and get a little better idea of where your problem might be and then you'll have more to go on (or ask about).
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 06-19-2007, 05:45 PM   #3
larry may
Re: Wiring
The dash lighting may be a result of the bulb sockets not making contact with the circut sheet on back of the instument housing. Below is an easy to read electrical diagram. Good luck . Larry
http://www.geocities.com/chevroletc1070/wiringdias.html
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 06-19-2007, 07:59 PM   #4
semperfidoordie
Re: Wiring
thanks...well the cargo light in the cab isn't there and I can't seem to figure out what kind of bulb it is...the wiring in this truck is a MESS to say the least...and i don't know anything about electronics haha...i'll check that stuff out though thanks
Tony
Old 06-19-2007, 08:23 PM   #5
Chevelle454
Chevelle454's Avatar
Re: Wiring
Do the gauges themselves not work or is it the lighting for them that doesn't work? If the gauges don't work check the oil line coming from the back of the block(behind the distributor). Make sure the oil is making it up to the gauge.
For the water temp gauge, locate the wire going to the sender (usually on one of the heads, but could be on the intake manifold). Ground the wire out and see if the gauge goes all the way to hot. If it does, the sender is bad. If not, check further down the line and see if the wire is broken somewhere.
As for the battery voltage, mine is still broken also so I can't help you with that.
Cab lights should be simple. Hook all the wires together (if they are a single lead; if they have two leads pick one off of every light and ground it). Bring a wire down to the headlight switch and probe for a wire thats hot when the parking lights are on. Splice in there.
Hope this helps a little, it's kinda hard to explain electrical stuff...
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-19-2007, 08:29 PM   #6
semperfidoordie
Re: Wiring
The gauges themselves don't work...the lighting behind them works fine. The only thing with the cab lights I don't get is that there is wires (if you're sitting driver) where the cab bends and goes flat against the bed and they're cut...and i have no idea what they go to or where they hook up to...from the looks of the plastic thing around them they belong there but it's confusing....
Tony
Old 06-19-2007, 09:38 PM   #7
lbpd719
Zappaphile!
lbpd719's Avatar
Re: Wiring
Can you get us some pics? might make it easier to help ya..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-19-2007, 11:04 PM   #8
semperfidoordie
Re: Wiring
Friday I get back home and I can get pics...i'm stuck in Yuma..aka hell on earth haha for an exercise to get us ready to go back to Iraq right now..
Tony
