Old 09-17-2002, 12:58 PM   #1
mikep
Used to have a truck
mikep's Avatar
side marker...lights?
Ive got new side markers with the light holes already cut out. Think I'll go ahead and make them functional. Do the side markers light with the turn signals or wit the standard running lights?
No truck :-(
mikep is offline   Reply With Quote
Old 09-17-2002, 01:10 PM   #2
COBALT
COBALT's Avatar
I heard they just work with running lights, but wiring them up to work with the turn signals wouldn't be too hard.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-17-2002, 02:17 PM   #3
mikep
mikep's Avatar
I think I'd rather have them with the turn signals. A wiring I will go.
No truck :-(
Old 09-17-2002, 03:02 PM   #4
MStokes
MStokes's Avatar
I'm pretty sure mine come on with the running lights and also flash with the turn signals. One strange thing I have noticed is that they flash out of sequence with the front and rear turn signals. Does anyone know if this is normal or do I have another wiring gremlin?
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 09-17-2002, 03:09 PM   #5
busterwivell
Mine flash out of sequence, front only
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 09-17-2002, 06:29 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Some flashed, some did not.
I've had 2 '70 chevys now, and the 3/4 ton flashed...but the one ton does not. Both harnesses were untampered.
To make it flash, run the ground wire from the side marker to the turn signal wire on the front marker. When the tun signal is not powered, it acts as a ground...and when it is powered, the ground is intureupted.
The rear ones never blinked.
Old 09-17-2002, 09:05 PM   #7
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Wiring them is easy like Longhorn said. If you reverse the wires like he said it will make the fronts flash out of time with the turn signals. The back ones never did flash on any of mine. I don't think they were made to. You just run the wires to them from the Brown wire for the hot side and a wire to ground for the other side. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
