Ok, I've got my "chunk" of an 87 chevy ft. end, now what?
Ok, this Q. may of been asked before, but here it goes....I have an Idea, but does anyone have any tips on the best way to swap out my 8 lug parts for my newly aquired 5 lug parts? I am replacing the spindles w/2.5" drop spindles and new drop springs. I've done some measuring and found that allmost all the holes match up so do I have to drill the rest, and my C-20 set up has a sway bar but the 87 frame does not ....will my existing sway bar mount up ...thanks Joe K
1969 chevy C-20 (soon to be shortened & Tubbed C-10) 1990 Astro AWD 3" Lift w/Laredo tires 10 spkr. 800w system and DVD player for the long trips (got it for free) ![]() ![]() |
Re: Ok, I've got my "chunk" of an 87 chevy ft. end, now what?
The 87 crossmember will bolt to the 69 frame. I think you have to drill one hole on each side IIRC. I wouldn't recommend cutting your frame and welding the 87 one in. Not sure if you had that planned or not but swapping bolts would be much easier i would think. As far as the sway bar, I think it would work. Someone else may know more about that. I'm using a 72 1/2 ton sway bar on my 68 but I don't really know if the size on the 3/4 ton is the same or not.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
English Chevy Owner
I have the sway bar from an 80's One ton one my 67 so the sway bar will bolt straight up after you remove one rivet either side from the frame.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
![]() Join Date: Nov 2004
I'd rebuild the suspension while it's all apart.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Thanks guys, I did unbolt the old frame and I see the ones to drill out, and I'm glad I can use the old sway bar. I have tons of pics to put up to show my progress.....thanks again Lil-Joe
(It will say Joe K's name 'cause I'm on my dads pc, but It's me Lil-Joe) Last edited by joe k; 06-23-2007 at 09:26 PM. |
