C10 Club Tennessee
Getting mad at my brakes
Okay, my driver's side front brakes are sticking. I changed to the Early Classic Brake hoses, and also changed the caliper. Any other suggestions???
I was thinking the proportioning valve, don't know what else is left.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
I am a Referee of life.
Re: Getting mad at my brakes
Brian,just go buy yourself a Colorado and bring me the truck,I will figure it out and take care of it so you can quit stressing.
![]() I haven't a clue unless there is a problem with the new caliper or the rotor has a run out issue.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
C10 Club Tennessee
run out issue?
![]() Join Date: Jan 2000
Are the rubber flex hoses that attached to the caliper original?
The inside of the hose can deterioate and cause caliper sticking. |
C10 Club Tennessee
nope, brand new hoses. Just bought them from Early Classic about 2 months ago. probably haven't put 300 miles on the truck.
Mejor Que Nada
Did you make any other changes before this issue arose
The only thing that separates "Dreams" from "Reality" is TIME and MONEY!!! |
C10 Club Tennessee
nope, changed the other caliper out. I was painting them and broke off a bleeder screw on the pass side, but the driver's side just started this a while back.
I used to work on school busses, and on one Chevy bus I was working on, I had 1 front wheel that was sticking. Tried everything, calipers, hoses, master cylinder and pads. Finally in frustration, I changed front brake pad brand...and believe it or not.....no more sticky brake. Weird
Is everything clean?
My left front drum was sticking on my 69 this spring and I took it apart, nothing looked wrong. I cleaned everything with brake clean and put it back together and no more problems. Could you have gotten grease on the pads when installing/reassembling?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
I was thinking maybe the rotor isn't true or maybe is warped a bit.
member #16
![]() Join Date: Dec 1999
I would try jacking it up and applying the brakes, Then crack the bleeder screw loose. If it doesnt release I would say you still have a stiff caliper.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Are the calipers new or remanufactured?
#13 |
no brain no headache
how are the sliders? If they are stuck, take them out (if you can) clean them up and grease them up with brake lube.
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
#14 |
New Member
![]() Join Date: May 2007
What about bearing pre-load? Can you wobble the disk (side to side) with your hands? Did you torque the axle nut to spec, back it off and re-torque. Maybe a slight blockage in the front brake line from the tee to the hose.
Mysteries like this are tough to noddle out but there's great satisfaction when solved. Hang in there.
Steve 67' C20 - Newest - My junkyard dog and work in progress |
#15 |
C10 Club Tennessee
They are reman calipers, I believe A1 cardone
Sliders?
#16 |
![]() Join Date: Nov 2001
I agree, the little sleeves that the bolts go thru, I would take the caliper off and not only be sure these are free of debri (these should slide in and out but with some resistence), but also be sure your caliper piston slides in and out (if may not be easy, but I would think you could push it back in by hand...???)
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 06-21-2007 at 11:51 PM. |
#17 |
C10 Club Tennessee
Just to make sure we are on the same page.
I have a front disc on a 70, but it looks like it's probably a late 70's disc brake setup. So it's the 52 pads. At most parts stores it's D52, MKD52 The ones with the hole on the outer pad.
#18 |
C10 Club Tennessee
okay, got to playing with these things a little today. everything seems to be clean and moving freely. When i spin the driver's side tire it makes it about another 1/2 turn and comes to a stop. I can see the outer pad move up about a 1/4 inch and then grab the rotor. I opened the bleeder, but no difference.
#19 |
looks like the rotors are warped. By the way you described it, it is beyond machinable. Look into a new set of rotors. If your rotors now are brand new with no miles on them i would looking into taking them back.
#20 |
C10 Club Tennessee
had them turned at O'Reilly's when I worked there a few months ago. I'll get a new set.
