Licensed to Thrill!
New Alan Grove 100R A/C Bracket - $85 Shipped
I have a brand new never used Alan Grove 100R A/C bracket that mounts on a SBC passenger side with a SWP.
![]() From AG website: "Our MOST POPULAR BRACKETS. Bolt to top water pump and the two front intake bolts. May be used individually or as a pair. Will clear tall valve covers. NO DRILLING OR TAPPING REQUIRED." This is made to work with the Sanden compressor. Save on shipping, and tax. I have to buy another bracket, so I just need my money back out of it. I'll take the hit on shipping. DLB |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Re: New Alan Grove 100R A/C Bracket - $85 Shipped
Will this work with the stock compressor?
and also does this include the alternator bracket nad does it intefere with the stock PS pump bracket? Thanks, |
Licensed to Thrill!
I will check to see if it will work with the stock compressor, because I don't know.
This is the A/C bracket only. The matching Alt. bracket is available from them direct or through a dealer - (200L) http://alangrovecomponents.com/S.B.Short_Pump.htm It doesn't interfere with the stock PS pump bracket. It mounts only on the water pump. DLB Last edited by Orange; 06-21-2007 at 08:00 AM. |
Licensed to Thrill!
It seems that this is for the Sanden style compressor only.
I didn't call to confirm this - but the holding it up to my Sanden, the mounts fit between the tabs on it, and the stock compressor is so much longer I just don't see it working. DLB |
Ok, Thanks.
If this were the one that puts it out past the Valve coversI wwould be all over it!! TTT for ya!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Licensed to Thrill!
To bad it isn't what you need Shawn.
That is actually what I ended up with. These are pretty clean looking too though. A lot of folks like the engine to be together, and not "all sprawled out". I may just stick it on eBay. I need it out of my way, and need other parts. DLB |
