Old 09-17-2002, 02:49 PM   #1
Kas68c10
Kas68c10's Avatar
ammeter/alternator help needed
I upgraded from stock to a one wire, 60 amp alternator about 3 months ago. I had a gauge cluster screwed to the bottom of the dash, and everything worked just fine. Then I replaced the stock idiot light dash with an all gauge type, with teckh tips from GMCpauls website.(he returned a question via email in one day, for those who may want to know). It went really well, it all worked fine except the ammeter was way over to the 'C" side, way, way over.
That lasted for about 20-30 minutes of running time, now I dont even see the needle! Must have burnt it up !!! Would going to a higher output alternator cause this, or do you think the gauge was on its last legs ?
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 09-17-2002, 07:31 PM   #2
68 with 350 TPI
68 with 350 TPI's Avatar
I would check the connection and make sure the guage is really dead.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
