Old 04-27-2002, 06:30 PM   #1
70jimmy4x4
Post Identify my suspension
Who can I send a pic to for some I.D.
I am trying to determine how much, if any,lift is on my Jimmy.
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
contact me: email--showme219@aol.com
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
Old 04-27-2002, 08:39 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Post
How does it compare to this:
No lift, factory heavy duty front/rear springs, 325-60R15 tires on 15x10 rims. I did replace the front spring bushings and body mounts. If you only have 2 or 3 leaves up front probably stock and will have a reverse arch also I believe the front springs are 3" wide on each end and taper to 2.5" in the middle, most aftermarket springs are 2.5" wide the whole length of the spring. You can email me your picture if you want; jimandtamara@yahoo.com
Hope this helps.
1970 GMC K25 Custom
Chesapeake, VA
My 70 GMCor Webshots http://community.webshots.com/user/70gmc
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-27-2002, 09:55 PM   #3
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
send me the pics, impalass@cruzers.com i'll post it here to if i cant figure it out
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 04-28-2002, 03:28 PM   #4
70jimmy4x4
Post
ttt
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
Old 04-29-2002, 12:30 AM   #5
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
[img]http://communities.msn.com/_Secure/0KwAAAJcNIBpjFZe5jzjjDvzVS0AhNk*d6UQV1qGsQTxvEpaF1BCpV*!weXVD6eoWBwWUaTlGFrM/'70jimmy.jpg[/img]
deffintly lifted, a good 2-4"s
My Truck pictures
64ImpalaSS 327
Old 04-29-2002, 09:42 AM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
Yep, I'm guessing 4" especially when you consider the stock springs have a slight reversed arch.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-29-2002, 09:57 AM   #7
70jimmy4x4
Thumbs up
Thanks guys... Felt silly for askin', but now I can ask the right questions when I get ready to dive into the suspension issues I hope to address !
cudos to the board !!!!
'70 jimmy 4x4
'65 stang
'81 shovelhead
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
Old 04-29-2002, 10:59 AM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Talking
Definetly at least 4" because of the raised steering arm.
1970 GMC K25 Custom
Chesapeake, VA
Old 04-29-2002, 03:21 PM   #9
Blazer1970
Blazer1970's Avatar
Post
Yup, I'd say 4". You can see why many lift companies sell 6" rear springs with a 4" kit for Blazers.
Blazer1970 is offline   Reply With Quote
