Old 06-20-2007, 11:26 PM   #1
krue
Designated A-hole!
krue's Avatar
Edelbrock 1406 questions
Got it mounted, now I need to know where to hook my vacuum lines to it. I need to run one to the dizzy, but where do I hook it on the carb? I have a fitting on the manifold for the tranny and I know where to hook the vacuum for the booster, I guess I just plug the leftover fittings. Oh yeah, where do y'all connect the power wire for the choke?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-20-2007, 11:34 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Edelbrock 1406 questions
I think it is the port on the left front of the carb (facing the truck from the front. Check to see if it has vacume at idle, if not then that's it. Power wire pull it from a keyed 12v source. I pulled mine from the junction (fuse block) keyed power.
70rs/ss is offline   Reply With Quote
Old 06-20-2007, 11:36 PM   #3
casterbuster
Mejor Que Nada
casterbuster's Avatar
I have the 1405 which is a mechanical choke so i can't help you there,
I am using the port on the front of the carb going to the dizzy, there are two i use the one to the left if you are looking at it from the radiator.
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
Old 06-20-2007, 11:37 PM   #4
casterbuster
Mejor Que Nada
he beat me
Old 06-20-2007, 11:45 PM   #5
krue
Designated A-hole!
krue's Avatar
Thanks guys, I just need to pick up some vacuum tubing and I'll be ready to try her out.
www.daveramsey.com
Old 06-20-2007, 11:50 PM   #6
70rs/ss
70rs/ss's Avatar
I'll bet you like it, especially if you are changing from a quadra-dump.
Old 06-20-2007, 11:57 PM   #7
krue
Designated A-hole!
krue's Avatar
That's the hope anyways. Yeah, it had the original quadrajunk on it.
www.daveramsey.com
Old 06-21-2007, 12:07 AM   #8
casterbuster
Mejor Que Nada
The PO of my truck was a creative fellow. He installed the carb with the mechanical choke, but didn't have a way to control it in the cab... ah hah the original a/c is gutted so he decided to use the hot to cold slide lever on the a/c panel... Cold means it's choked Hot means it's open.
I still haven't fixed that yet... Not to mention he had the dizzy plugged into the right port, but for some reason had plugged the line on purpose...
Old 07-19-2007, 04:46 PM   #9
bad6772
Official Site Guitar Shredder
bad6772's Avatar
aw man doggin qaudrajets, lol there great carbs if you know how to work on them , ive seen tricked out quadrajets support 500 horses easy i had one on my 406.it was a olds bottom and caddy top, cfm was 850 was a great carb, i say that but i swear by edelbrocks, great carbs for the money and basically no tunning outa the box
bad6772 is offline   Reply With Quote
Old 06-21-2007, 12:57 AM   #10
Billla
Billla's Avatar
OOOOoooo don't open that can of worms again There are two small vacuum ports on the front - one above the throttle butterflies (ported) and one below (manifold). If you have a stock or very mild engine, hook to the ported vacuum. If you have a bit of a cam, etc. IMHO hook to the manifold vacuum to get a better idle.
I ran an IGN UNF line out and split it for my Pertronix distributor and the choke.
Billla is offline   Reply With Quote
Old 06-21-2007, 07:28 AM   #11
Orange
Licensed to Thrill!
Orange's Avatar
Billa - you still talking about the small ports on the left and right?
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 06-21-2007, 08:40 AM   #12
Billla
Billla's Avatar
DLB
Yes; there are 3 ports on the front; the two smaller ones to the left and right of center and the big one in the middle
Old 06-21-2007, 09:41 AM   #13
Orange
Licensed to Thrill!
Orange's Avatar
Right - so which one is which?
The one above the throttle butterflies (ported) and one below (manifold)?
(From the front of the engine)...
DLB
Old 06-21-2007, 11:07 AM   #14
Billla
Billla's Avatar
DLB
http://www.edelbrock.com/automotive_...ers_manual.pdf
Old 07-19-2007, 05:11 PM   #15
piecesparts
Parts and more parts
piecesparts's Avatar
I agreee with Billla on the connection of the vacuum ports. I am running a somewhat lopey cam in my 383 and the non-ported vacuum source works the best to get my dizzy advancing early enough. A mild engine that has a stock dizzy (not one that has been reworked and modified) works better with the ported fitting. My engine gets right up to speed and the choke works fine, I also get around 15 MPG with the Edelbrock AVS carb (it is just a little bigger than the 1406 in CFM ratings.
piecesparts is offline   Reply With Quote
Old 06-21-2007, 07:45 AM   #16
mrein3
mrein3's Avatar
The PO of my truck eliminated the spark emissions control thingy relay with a side cutter. I discovered that that wire has 12V when the key is on. And it was "terminated" on the firewall. In my 4x4 the engine is already way back there so I just made a little extension to that wire and hooked the choke to that 12V source.
If I remember correctly that wire is green. It is an easy to find it with a test light. Just hook up the light, get in the cab, and cycle the key a few times. If it lights up with key on, you're good to go.
I'd post a picture but my hard drive took a digger last week. All my photos are on the other computer.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-21-2007, 10:40 AM   #17
67ChevyRedneck
67ChevyRedneck's Avatar
This picture sucks, but the one on the left is the ported vacuum that goes to the dizzy. The one on the right is the full vacuum I blocked off, and the one in the middle goes to your PCV. There's also one in the back for the brake booster
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-19-2007, 04:20 PM   #18
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
Yeah, you need to have that empty terminal hooked up, that's how your elec. choke gets it's power. Mine is run to an open 'ignition unfused' spot in my fuse panel.
Spanky_Pete is offline   Reply With Quote
Old 07-19-2007, 04:21 PM   #19
67ChevyRedneck
With the others. It needs to be hooked to a terminal that has power only when the key is turned on (so you don't kill your battery )
Jesse James
Project "On a Dime"
Old 07-19-2007, 04:35 PM   #20
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I love this board.. In 5 minutes I found out what I need to know. Thanks a million for the help.
Now, to find the time to get it done !!!!!!!!!!!!!!!!
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-19-2007, 04:39 PM   #21
Already Gone
I'm coming to your town next year for the GWRRA Wing Ding which runs from July 3rd to 6th, 2008.. There will be near 10,000 Honda Goldwings running around Greenvile then.. We booked rooms at the Hawthorn Suites, are you familiar with that hotel and is it a decent place?
Old 07-19-2007, 05:34 PM   #22
67ChevyRedneck
I've never heard of this "Wing Ding" before but I live about 10 miles from the hotel (I think, if it's the one pictured off Haywood Road, I've never stayed there before, I kinda live here, so I don't pay attention to local hotels )
Jesse James
Project "On a Dime"
Old 07-19-2007, 04:58 PM   #23
70rs/ss
70rs/ss's Avatar
One other tidbit here. If you look at your pict you can see that the choke is also adjustable for lean/rich. Once you have power hooked to it you can shorten the choke time or lengthen if it isn't warning up enough!!
Old 07-19-2007, 05:11 PM   #24
Already Gone
Thanks !!
Old 07-19-2007, 06:07 PM   #25
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I hope you enjoy it.
I pulled the 1406 off of my truck and replaced it with a 190somenthing. It's the Quadrajunk that someone mentioned. In my case, it has been flawless. The old carb was jetted much richer, and my nose knew it. The Q-Jet was so much leaner out of the box that I had to put a shield on the starter solenoid to cure a heat-soak issue.
Different strokes for different folks.
Member Nr. 2770
