06-20-2007, 11:35 PM | #1 |
She won't fire!
Just picked up a'58 Apache. It has been sitting for 15 years. It will turn over and has power (12 volts) to the coil and on to the distributor when the key is on. when I crank it there is no spark to the plugs. I have removed one and grounded it looking for the arc. Bad Coil? Condensor? Points?
06-20-2007, 11:51 PM | #2 |
Re: She won't fire!
usually that is bad condenser causing open. pull dizzy cap and withkey on check points by manually opening and closing them with screwdriver or just crank it over and watch points for spark. good luck.
06-20-2007, 11:52 PM | #3 |
Hollister Road Co.
Re: She won't fire!
Bad all of the above. but try the points and condensor first
06-21-2007, 11:00 AM | #4 |
Re: She won't fire!
Thanks! I will try it out and post.
06-21-2007, 12:13 PM | #5 |
polishing a turd
Re: She won't fire!
i get mine to fire up when i found it, i replaced the coil, distributor cap and rotor, plugs, plug wires, rebuilt the carb, cleaned the gas tank, and put in a new fuel filter.
the points on mine were firing, maybe not with the ideal gap, but enough to get it moving. if you have no spark, you may need to replace the points also if they don't fire
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
06-21-2007, 03:18 PM | #6 |
Re: She won't fire!
My 59 GMC (Canadian with 235 I6) has a resistor on the firewall. When it goes I do not get spark.
You can test it by simply wiring it directly and then trying it. For a new one just go to a Dodge dealer as they used them with low energy ignition into the 80's. When mine would go I would hook the two wires directly and then drive over to the Dodge dealer. Two screws and I was driving again. Good luck.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
06-25-2007, 10:45 AM | #7 |
Re: She won't fire!
Replaced the coil, points and condensor, poured a little fuel in the carb and she fired right off. She won't run though on what used to be gasoline in the tank. I am planning an alternative setup to run the engine for 10 - 15 minutes to check it out before I tear down the truck for restoration. The P.O. told me the engine ws rebuilt 5-600 miles before he parked it. I will compression test it and if it is OK that will be one less item to build from scratch. I'll just clean it up and paint it before reassmbly.
06-25-2007, 05:00 PM | #8 |
polishing a turd
Re: She won't fire!
yeah, you need to dump out that gas. don't kid yourself into thinking you can dilute it with good gas. you need fresh gas in the tank.
