Old 06-21-2007, 11:32 AM   #1
LockDoc
The Older Generation
LockDoc's Avatar
72 Chevy Frame w/ 4.10 Eaton Rear axle
Please respond in thread.
I have the frame from a '72 Chevy C-20 for sale. It was a driven truck about a year ago that has been dismantled. It has the complete front crossmember under it but the A-arms are shot. It has the front spindles w/rotors & calipers. The drivers side rotor looks good but the pass. side has some grooves in it. Front half of the frame is good but the back half is bad. The trailing arms are shot also. It has a 4.10 Eaton rear with a two piece drive shaft. I'll take $75 for the whole thing picked up here in South Central Iowa. This does not include the wheels & tires.
I have a cutting torch and Plasma cutter so you can take as much or as little of it as you want. Any questions post 'em up.
Thanks.
LockDoc (Leon)
Leon
Old 06-21-2007, 10:17 PM   #2
masterbeavis
Having issues
masterbeavis's Avatar
Re: 72 Chevy Frame w/ 4.10 Eaton Rear axle
Have you checked the rearend for a detroit? All you have to do is lift one tire and try to spin the driveshaft. You never know, you might find gold. (I did once on accident, almost gave a rearend away before I checked it)
masterbeavis is offline   Reply With Quote
Old 06-21-2007, 10:47 PM   #3
LockDoc
LockDoc's Avatar
Thanks for the tip MasterBeavis.
I took a couple of pics with the cover off and posted them a while back. The consensus was, no locker.....
LockDoc
Leon
Old 06-22-2007, 12:08 AM   #4
masterbeavis
Having issues
well, thats a dead giveaway, them pesky spider gears.... Maybe next time you otta spray some pesticide on the housing to make them go away....
