06-21-2007, 02:00 PM | #1 |
Junior Member
Rearend Gear
Does anybody know what rearend gear came in a 69 1/2 ton 3-speed manual?
Keith |
06-21-2007, 02:14 PM | #2 |
Re: Rearend Gear
just a guess 3.42-3.73, 4.10 maybe? I'm sure others will chime in with more accur. info!
R.I.P. Killer 71 10/26/07 |
06-21-2007, 02:28 PM | #3 |
Re: Rearend Gear
Keith,
I think 3.73 was standard equipment and the 3.07 and 4.11 were optional thru '71.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
06-21-2007, 03:08 PM | #4 |
its all about the +6 inches
Re: Rearend Gear
no 3.42 ever offered.
If nothing is listed on the SPID, then a 3.73 was standard, and is assumed. 3.07 was avalible, as was 4.11, not sure if they were both avalible with the 3 speed, nor what ever engine you have. (there were some limitations) Your best bet would be to remove the cover and count the teeth on the 2 gears, divide one into the other, and then refill with new oil. Old oil doesn't offer much protection. |
06-21-2007, 03:44 PM | #5 |
Re: Rearend Gear
What engine was in it from the factory
06-21-2007, 06:01 PM | #6 |
Re: Rearend Gear
The Truck Data Book I have for 1969 says 3.73 was standard on C10s,but that doesn't mean that's what you have.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 06-21-2007 at 06:01 PM. |
06-21-2007, 06:22 PM | #7 |
Re: Rearend Gear
My 72 was an original "3 on the tree" 350 truck and the rear was a 3.73.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
06-21-2007, 09:27 PM | #8 |
Re: Rearend Gear
if it has a 3 speed, and nothing was optioned, then the 3.37 was standard.
if it has a 4 speed, or a TH350/TH400, then you got a 3.07, unless otherwise optioned. |
06-21-2007, 09:56 PM | #9 |
Re: Rearend Gear
My 68 3 on the tree came standard with a 3.73
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
06-21-2007, 10:56 PM | #10 |
Junior Member
Re: Rearend Gear
06-21-2007, 11:04 PM | #11 | |
Junior Member
Re: Rearend Gear
It was original with a 250 I6 and three on the tree. The PO installed a TH350 in it, but didn't change anything on the rearend. I don't think. If that's the case then I am sure I have a 3:73. I am picking up the chassis from BowTieOgre on Saturday morning, and his has a 3:73 rearend. I have a crossmember and rearend from a 72 that I was going to swap with my truck, and the rearend has 3:08 rearend. I was wanting the 3:08 for better 60-65 mph driving. The truck is awful with the gear it has, but I was thinking a higher gear would be nice. I guess what I am trying to figure out is which gear should I go with? I do intent on switching to a 700r4 in a year or so and I think I would be happier with the 3:73 when that day comes. What do you guys think? Keith |
06-21-2007, 11:06 PM | #12 |
Re: Rearend Gear
I think Longhorn man meant 3.73, oh my god, I think this might be the very first time in over 59,000 post's that he was wrong, wow......I'm in shock
06-21-2007, 11:18 PM | #13 |
Re: Rearend Gear
I've been wrong plenty.
That was a dislexia induced typo though |
06-22-2007, 07:36 AM | #14 |
Re: Rearend Gear
He was right,then wrong due to dislexia.Yo Longhorn Man,you dissin`on us?
I think you`ll be happy with the 3.08s & o/d as long as you have a couple horses under the hood.That combo is popular.
06-22-2007, 05:12 PM | #15 |
Re: Rearend Gear
with an overdrive I would recomend the 3.73... not the 3.07. Seen too many ppl claim a drop in MPG.
06-22-2007, 05:51 PM | #16 |
Active Member
Re: Rearend Gear
i am not sure what my truck has ( i think 3:73 ) and when in drive with my th350 it seemed like it needed another gear
but i have now a 700r4 tranny and i want more gear i think i need 4:11 |
