Old 06-21-2007, 03:13 PM   #1
matthufham
changine ball joints
the uppers bolt in no sweat
the lowers have to be pressed in? can i do this at home without a press?
it's a 72 1/2 ton, 2 wheel drive.
edit: i typed the subject too fast, my bad. "changing"
matthufham is offline   Reply With Quote
Old 06-21-2007, 03:48 PM   #2
woodridge
woodridge's Avatar
Re: changine ball joints
The lower joints can be "manually" replaced i.e. big hammer. You should be able to rent a ball joint press from the local parts store which makes the installation easier. To do it manually, remove the steering knuckle from the lower bj. Support the control arm at the outer edge, remove the grease boot and using a big hammer, drive the bj out striking it on the lip sticking up above the control arm. To install, place the new joint up through the hole then support the control arm under the new ball joint allowing considerable weight to be applied. Next, using something blunt, drive the control arm down over the ball joint. Install new zerk, dust boot and steering knuckle.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 06-21-2007, 03:55 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Are you removing the A-arms? I tried the above method (to an extent) and ended up ruining a ball joint, buying another, and using a press at my uncle's shop. Not saying it can't be done, just saying I screwed it up. To me, it would be worth borrowing/renting a press. Top ones are easy, grind out old rivets, install new with bolts. Be carefull removing the ball joints with the spring!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-21-2007, 04:19 PM   #4
ChevyDude
With the ball joint press available for rent for FREE at most auto parts stores....Do the big SKIP on the above manual stated method.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 06-21-2007, 04:23 PM   #5
woodridge
woodridge's Avatar
I agree. Only explained it as a last resort method.
Old 06-21-2007, 05:08 PM   #6
Jim_PA
I got my 4-n-1 service kit (ball joint and ujoint, and some other duties) from Harbor freight for like $20. It worked great.
Jim_PA is offline   Reply With Quote
Old 06-21-2007, 05:14 PM   #7
matthufham
if i don't have to, i don't want to remove the control arms. i got new tie rods, ball joints, rotors and bearings. and i plan to cut my coils and upgrade the steering gearbox all at once
