Old 06-21-2007, 04:36 PM   #1
jorgensensc
jorgensensc's Avatar
292 and 475 auto overdrive tranny? WIW
I have a neighbor that says he has a 292 six with a four speed auto overdrive tranny called a 475? He was a tranny rebuilder and seems to know what he is talking about when he is coherent (long story). He is moving soon and thought it might be a nice combo to have on standby. Any idea what something like that is worth? Is the 475 tranny a good one or what?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-21-2007, 04:41 PM   #2
70rs/ss
70rs/ss's Avatar
Re: 292 and 475 auto overdrive tranny? WIW
375? It was put into the newer chevy trucks but it was only a 3-speed? It is between a 350 and 400 and was put behind the 454's in the 454 SS trucks and some others. I was given two 292 and I can't get rid of them. Can you get some picts of the trans and motor? I am by no means an expert, but nothing GM comes to mind other than the 375?
70rs/ss is offline   Reply With Quote
Old 06-21-2007, 04:51 PM   #3
jorgensensc
I googled it and found out it is in the turbo hydramatic family of 350 and 400, but that's about all I can find.
No pics, just rebuild manuals.
Shawn
Old 06-21-2007, 05:14 PM   #4
woodridge
woodridge's Avatar
475? That's a new one for me. GM built a 425 but that was a FWD tranny used in the Eldo's Toro's and Rivi's and it was not an overdrive.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 06-21-2007, 05:27 PM   #5
70rs/ss
70rs/ss's Avatar
I googled and here is what I got, 475 is a front wheel wonder, how'd he mount that to a rear wheel drive motor setup? But acording to this the 375 isn't supposed to have been behind my 454 in my 90 SS?
Hydramatics are NOT all the same.
General Motors calls most of their transmissions hydramatic. A little bit of History
Single range hydramatic produced from 1938-1951
Dual range hydramatic produced from 1952-1962
(used only in trucks after 1957)
Jetaway hydramatic produced from 1956-1964
Jetaway Roto 10 (Slim Jim) produced from 1961-1964
Jetaway Roto 05 produced from 1961-1963
used in Oldsmobile Cutlass)
Turbo Hydramatic 300 produced from 1964-1968
Turbo Hydramatic 375 produced from 1968-1975
Turbo Hydramatic 400 produced from 1964-1991
Turbo Hydramatic 425 (front wheel drive) produced from 1966-1978
Turbo Hydramatic 475 (heavy duty front wheel drive)
Turbo Hydramatic 350 produced from 1969-1985
Turbo Hydramatic 325 produced from 1979-1981
Turbo Hydramatic 325-4L produced from 1982-1985
The above transmissions were produced with the exception of the 400 prior to 1985 and since then there have been many, many more. So when you say Hydramatic it can really mean a lot of different transmissions. Hydramatic is actually the name of a division of General Motors that produces transmissions.
Old 06-21-2007, 07:33 PM   #6
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
There is a TH-475, Its pretty much the same as a 400 but has straight cut gears instead of helical. Stronger than the 400 but more noisy, youll find these in motor homes, box vans and buses. I dont know if this is the same tranny he is talking about since these are not overdrive.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 06-22-2007, 08:04 AM   #7
Maybe he wasn`t coherent?The 292 is in demand these days.I want one,but needs to be local.I`d say worth as much as any old running small block.
Old 06-22-2007, 09:10 AM   #8
BUDDY
Global warming is a myth
BUDDY's Avatar
Thumbs up Re: 292 and 475 auto overdrive tranny? WIW
I agree!
I think that this transmission may have been offered with a converter lockup option as well, which would give the impression of a 4th "gear" but in reality is just the clunk of the converter locking up.
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 06-23-2007, 04:25 PM   #9
OhNoJoe
OhNoJoe's Avatar
I looking to rebuild or get a low mile 292. It's the only way to go!!
OhNoJoe is offline   Reply With Quote
