Old 06-21-2007, 08:18 PM   #1
LpStreetKing
LpStreetKing's Avatar
anybody know if 35 inch tires will fit under a 6 inch lift
yea i really could use yalls help cause i am wanting to lift my 83 swb GMC sierra 1500 and do yall know what kind of motifications i might have to make on it if yall could reply back to me with yalls answers i would greatly appretiate it
LpStreetKing is offline   Reply With Quote
Old 06-21-2007, 10:16 PM   #2
LonghornJeff
EZEKIEL 25:17
LonghornJeff's Avatar
Re: anybody know if 35 inch tires will fit under a 6 inch lift
try this link...
http://67-72chevytrucks.com/vboard/s...d.php?t=211796
and Welcome to the board
68 CHEVELLE(HORSESHOE)
69 LONGHORN 396
70 NOVA 454(FOR SALE)
71 SWB 307
71 EL CAMINO 383
72 GMC JIMMY 350
87 BLAZER 350 WIW?
http://blog.360.yahoo.com/blog-r5CJt...9_6Orzim4L5uWM
Gun control, the theory that 110lb. women have the "right" to fistfight with 210lb. rapists.
The reason animal rights activists are more passionate about fur than leather is because it's safer to harrass rich women than bikers...
LonghornJeff is offline   Reply With Quote
Old 06-21-2007, 10:23 PM   #3
eedgell
It's the air up here
eedgell's Avatar
Thumbs up Re: anybody know if 35 inch tires will fit under a 6 inch lift
I think 4in of lift will get it done as long as you are not wheeling real hard. In that case 6in is better. Mostley the front corners of the front fenders will take a beating when wheeling hard with 35's and 4in. The rear will be just fine. Unless you like the big rocks, or you have a lead foot and like to jump, you will be fine with the 4in. and 35's.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-21-2007, 11:46 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
6" lift should be fine. U probably will have to lengthen your drive shaft. 6" lift is on the borderline. Probably will have to extend your brake lines as well.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 06-22-2007, 06:28 AM   #5
b454rat
I would go 6". I had a 3/4 ton with 6" and running 35s, and once in awhile I would hit the fender. It was a nice truck, so didn't want any rubbing at all. I was running wide boggers, which didn't help any.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-22-2007, 08:14 AM   #6
4"Superlift,12.50/35 BFG A/Ts,9.75" steel wheels,Heckothorn Hydraulic shocks.Rode good,never rubbed.Never wheeled it hard either.But,almost always hauling weight.Diesel motor and loaded lader rack put`s the weight up front a good bit,too:
