Old 06-21-2007, 09:46 PM   #1
fercho71
fercho71's Avatar
advise on a diferential
hi !!!!!!!!
hello everyone i am new to this page i just bought a 1966 chevy 3/4 ton pick up i believe its a c-20 not an expert so i dont really now the advise i need its i jus come to a problem the diferential its damage so i need to fix it or replace it i live in sandiego so i can look on a junkyard in tijuana and get it on better price than here in the us so my cuestion its what year for a diferential should i look for?
is it true that a camaro will fit and what year should thi be?
thank you i will pos mi pictures soon
fercho71 is offline   Reply With Quote
Old 06-21-2007, 10:01 PM   #2
LILRED66
LILRED66's Avatar
Re: advise on a diferential
fercho71:
Welcome from Kansas City, KS.
Anything will due, however it will not be a direct bolt-in swap. I wouldn't suggest putting a Camaro rear-end in a 3/4 ton truck. Anything from '60-late 70's will work, however you may have to make some changes to the shock mounts and Panhard bar mount. Why not find a direct replacement and save yourself the fab issues?
Good luck with your search. There will be several suggestions from fellow posters, that have done this swap successfully.
Tony
LILRED66 is offline   Reply With Quote
Old 06-21-2007, 10:12 PM   #3
fercho71
fercho71's Avatar
thanks for the advise !!!!!!!!!
Old 06-22-2007, 12:45 AM   #4
Captainfab
60-66 Nut
To be able to give advise, a little more info is needed. Do you want to keep it 3/4 ton? what are your plane for your new truck?
Old 06-22-2007, 12:59 AM   #5
fercho71
fercho71's Avatar
if its posisble i would like to keep it as a 3/4 ton is it my model a c-20 series? and i would like to lowered a little bit
Old 06-22-2007, 01:30 AM   #6
Captainfab
60-66 Nut
If it has 8 lug nuts, it is a 3/4 ton. If that is the case, yours would be most likely be an Eaton rear differential....very few had Dana 60 rear differentials. The Dana 60's seemed to be more common in the '67-72's. Any rear differential in a 2wd 3/4 ton up thru 1972 will be a bolt in. The Eaton diffs are more difficult to find parts for when needed, so i would recommend looking for a Dana 60. If you or someone you know have welding and fabrication skills, you could install most any differential that you want. If you were to install a 14 bolt differential ( introduced in 1973, and still used to this day AFAIK) it is aprox 1 1/2" wider than the original. Which depending on your tire and wheel choice, could present clearance issues with the inside of the outter fender.
Old 06-22-2007, 03:11 AM   #7
NF65Fleetside
NF65Fleetside's Avatar
not to jack your thread but another question with diffs is that can you just swap gears as long as the housing boltage is the same?
NF65Fleetside is offline   Reply With Quote
Old 06-23-2007, 01:22 AM   #8
Captainfab
60-66 Nut
You can swap the gears, but they need to be re-setup(or atleast checked)for proper tooth contact and backlash. As long as you stay in the same family you'll be alright... ie: truck 12 bolt to truck 12 bolt, truck 10 bolt to truck 10 bolt, etc.That is unless you're dealing with a diff that has a removable 3rd member such as a 9 inch or the above mentioned Eaton, just to name a couple.With those you can just swap the whole 3rd member.
Old 06-23-2007, 11:35 PM   #9
fercho71
fercho71's Avatar
thank you very much guys i found it already here in sandiego on a shop and they will install it for $ 550 its a 3/4 don't know what kind but i will ask is it a good price?
1966 chevy c-20 truck " La Chata " under construccion
Old 06-24-2007, 02:37 AM   #10
fercho71
fercho71's Avatar
thank you guys here are some pictures of my truck http://community.webshots.com/user/fercho7112
