Old 06-21-2007, 11:59 PM   #1
raiden7800
Straight "6" Shooter
raiden7800's Avatar
Color Combos
What were the color combinations on the 64-66 c-10s. I think mine used to be white, and a reddish brown trim. I have seriously been thinking about going back to the original colors, since they wouldnt look bad. My poor truck has had about 7 different coats of spray on paint over the years. I was in the middle of sanding it, and some of it chipped off, and was white. I scrathed a bit further, and found 5 more layers of paint, and then white again before the metal. It may also have had some weird color of primer, but I am pretty sure that the truck was originally white.
Does anyone have an original factory order manual with the color options listed? If you do, is there a listing for engine block colors as well?
Thanks ahead of time!
Rob
1966 LWB 292 I6 & Granny Low
If you listen intently, you can hear a FORD rusting in the distance.
My LUG NUTS take more TORQUE than your HONDA makes!
raiden7800 is offline   Reply With Quote
Old 06-22-2007, 12:30 AM   #2
19GMC63
19GMC63's Avatar
Re: Color Combos
someone on here will get you a color chart or something.
Once you get a color idea or two or more, come on over to the photoshop forum and we can give you an idea of what it would look like.
19GMC63 is online now   Reply With Quote
Old 06-22-2007, 06:40 PM   #3
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: Color Combos
go on to www.autocolorlibrary.com they have all the factory chips online.
jerry
ClassicAutoResto is offline   Reply With Quote
