Rear Air Bag setup done simple???
Right now I have a 2.5 drop in the front and a 4" spring in the rear. When I put a load on the rear springs they just bottom out. I am thinking about going with airbags on the rear of my truck just to adjust the ride height under load conditions. What would it take do do this as a simple setup that could be expanded later, maybe?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
Re: Rear Air Bag setup done simple???
http://67-72chevytrucks.com/vboard/s...d.php?t=244558
?You can watch my thread. I'm on hold cause I'm going fishing but should be back at it soon.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
"Swapping to manual fill bags will get you where you want so why not bags? You're going to go through the effort of swapping springs anyway.... installing a couple of bags isn't much more work.
From SuicideDoors site: 255c 2500# Firestone air bags @ $70ea x 2 = 140 25ft 1/4" Reinforced DOT air line @ $6 90° elbow fittings @ $5ea x 2 = 10 Schrader fittings @ $5ea x 2 = 10 Grand total for everything = $166 Price for 5" drop springs from board vendor GMC Pauls = $115 $51 difference to get that 7" drop & still tow a load....." Scoti, Is this something you have done? Do you have a pic of this setup?
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S Last edited by 72 Cheyenne402; 06-22-2007 at 04:39 PM. |
Yes.... That's how I initially installed the bags on my 68.
I ran them that way for almost 3yrs before installing a tank/compressor w/controls. I've added more again. The front has bags now & I switched to Slams (I thought I would try them out). I also re-engineered a couple of things on the suspension to work a little better. As far as pics.... there's really not much to it. Bags in place of rear coils & 2 airlines running down the framerails to the bumper where I mounted the 2 schrader valves (they were installed behind my flip-up license plate).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-22-2007 at 08:36 PM. |
