Old 06-22-2007, 02:14 PM   #1
mvfd70
mvfd70's Avatar
Motor question
Will an engine out of a front wheel drive vehicle work in a truck? I'm looking at a Cadillac engine but it is in a front wheel drive car. Is there a way to convert it to rear wheel drive?
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 06-22-2007, 02:40 PM   #2
Re: Motor question
Yes it will work. You'll need the appropriate RWD tranny to hook to it though. Rememeber that Caddy does not use the same tranny/engine bolt pattern as Chevy. But a tranny from a RWD Buick, Pontiac, Oldsmobile, or Caddy will work. Of course you'll have other issues, like motor mounts, accessories, exhaust, and driveshaft. All very easily worked out though.
Old 06-22-2007, 03:46 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
Re: Motor question
It's been discussed on here before IIRC. The Northstar motors aren't that great IMO. They burn quite a lot of oil and I've seen them leak it pretty bad, too. They have a fix for the leak, but it was around 2K for the repair back when I was working at a Caddy dealership. The starter is also under the intake, which is a little if you ask me. They do put out quite a bit of power, and as Palf70 said they can be made to work. Good luck with whatever you decide.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-22-2007, 11:40 PM   #4
mvfd70
mvfd70's Avatar
Re: Motor question
Thanks. Don't know what I want to do. I've got a few options and still trying to decide.
