06-22-2007, 03:54 PM | #1 |
70knight
ignition installation problem need help
i need to now how to install ignition switch on my 1970 chevy pickup truck. I can't get the ignition out. I put wire in the hole but the ignition would not come out.
06-22-2007, 04:01 PM | #2 |
I am a Referee of life.
Re: ignition installation problem need help
WELCOME!!!!! to the greatest source for 67-72 Chevy/GMC truck info anywhere.
You may have to work the wire around a bit.You also need to have the key in the ignition.IIRC you need to turn the key towards the acc. position.It sometimes helps to work the wire in and out a few times to loosen the pin inside up a little.I have also WD40'ed the mechanism or used "Lock Ease" a graphite based lubricant for locks. BTW you can also do a search in the FAQ section for more info on this.Member krue has done a great job of compiling a guide for it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 06-22-2007 at 04:03 PM. |
06-22-2007, 04:18 PM | #3 |
The Older Generation
http://67-72chevytrucks.com/vboard/s...highlight=lock The removal info is toward the bottom. The link at the bottom isn't working though. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-22-2007 at 04:18 PM. |
06-22-2007, 07:35 PM | #4 |
70knight
thank you for the info. on the ignition switch I will tried it tonight. 70 knight
06-22-2007, 08:43 PM | #5 |
a paper clip works good too.. sometime it takes some jiggling
06-22-2007, 09:12 PM | #6 |
its all about the +6 inches
an allen wrench is best for the tool to poke with.
06-22-2007, 09:18 PM | #7 |
Saving 1 truck at a time!
It will take you 30+ minutes unless you are a magician...LOL! You can actually feel the allen wrench/very stiff paper clip depress the spring release for the dogs at the bottom of the hole. Jiggle like mad and pull the pin and key out at the same time...YES...they both pull out 99 out of 100 times and leave the barrel in place...JUST KEEP MESSING WITH IT...give up 5-10 times and then try again...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-23-2007, 03:10 PM | #8 |
70knight
I worked on the ignition switched today i spray it with crc and it came right out . thanks for all the help. 70 knight.
06-23-2007, 04:10 PM | #9 |
John, that's why we come here.It gives us a chance to show off our vast storehouse of information that is useless to anyone but lovers of these trucks.Others just tend to kind of wander away when someone starts going on and on about an old Chevy/GMC.So what's the next thing?
BTW There's an known rule that once we help with a problem we expect to see pics of the truck.J/K,but we do love pics.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-23-2007, 06:23 PM | #10 |
Welcome! Where abouts in NJ are you? I am in Budd Lake which is in Morris county in north west NJ. Chris
06-23-2007, 11:15 PM | #11 |
70knight
I live in bridgewater n.j. somest county. If you go south on 206 about 45 min.you will go arourd somville circle. I am 10 min from there . 70 knight
06-24-2007, 12:03 AM | #12 |
Zeeklu has one of the prettiest looking trucks on the planet. I don't want to sound light in the loafers but it is PRETTY.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
06-24-2007, 05:43 AM | #13 |
Thanks Bob. Small world John , I work in Branchburg right next door. Chris
06-24-2007, 12:49 PM | #14 |
So how long did it take you to get the ignition barrel out?
06-24-2007, 03:13 PM | #15 |
70knight
it take me about 20 min. to get it out and about 20 min. to put it back in . 70 knight
