Old 06-22-2007, 09:27 PM   #1
smh292
Cab questions
I found a local cab that is in better shape than the current one on my truck. The only bad spots appear to be the cab corners, rockers, and some of the floor near the doors. The new cab is for a maual and factory AC. The guy is keeping the AC unit. Would I have any problems converting this cab to auto and non AC? I don't know if the firewall is different and the pedal assembly is different? I have all the components in the old cab that I can swap over. Any thoughts?
www.diverserides.com
WTB 67-68 SWB, 350, Auto, Coil frame, Discs up front - PM me with details
smh292 is offline   Reply With Quote
Old 06-22-2007, 10:47 PM   #2
lbpd719
Zappaphile!
lbpd719's Avatar
Re: Cab questions
This should help..
http://67-72chevytrucks.com/vboard/s...d.php?t=225592
it's not everything you are asking about, but gives you an idea of the work involved..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-22-2007, 10:47 PM   #3
71tahoe
71tahoe's Avatar
Re: Cab questions
The clutch unbolts and you should be able to plug the hole where the rod went through the firewall.
I'm not sure about how much work it would be to install a heater only. I saw somewhere that the firewall openings are different for AC trucks. It might have been someone trying to sell something no one really needs.
71tahoe is offline   Reply With Quote
Old 06-25-2007, 03:04 PM   #4
smh292
Re: Cab questions
So it sounds like all I would have to do to convert to Non A/C would be to cut the dash at the dotted line and weld in the bottom portion from my original cab and weld a filler plate to the firewall so I could cut the different hole for the standard blower box. It sounds like the pedals shouldn't be too hard either. I'm still going to have to do cab corners, rockers, and some floor work. Whats your thoughts on $250 for the cab with a title?
Old 06-25-2007, 03:18 PM   #5
cdowns
cdowns's Avatar
Re: Cab questions
really no need to weld up the dash you can still run vent hose to the ac outlets from your heater and have a more evenly distributed heat during the winter
Old 06-25-2007, 03:27 PM   #6
faribran
Re: Cab questions
what are u waiting for.. you havent paid the guy yet ?? !!
faribran is offline   Reply With Quote
Old 06-25-2007, 03:57 PM   #7
smh292
Re: Cab questions
I just want to make sure I don't jump into something that would be more of a headache than it is worth. I like the idea of leaving the A/C vents - less work. I would still need to modify the firewall some and fix the typical rust areas. I might go look it over again and snap some pictures. I think he said he would throw in the tailgate also which was GM original.
Old 06-25-2007, 05:28 PM   #8
john
member #16
john's Avatar
Re: Cab questions
Its not hard to modify the firewall.
john is offline   Reply With Quote
Old 06-25-2007, 10:38 PM   #9
Re: Cab questions
The trans hump is no problem.Alot of guys smooth the firewalls and use Vintage Air.You don`t want a/c,or you don`t want to mess with getting a working factory a/c system together?I think it`s a good price.You would be about to get back out of it if you needed.
