Old 09-17-2002, 08:58 PM   #1
Paul Clark
After-Market Grills
If you aren't going to replace your grill (1972) don't read this.
As a "newbie" thought my slant on things might help others.
When mounting the insert, place a small socket under the square "posts". Use a small C-Clamp to pop them in - or just push until your thumbs bleed.
Had to cut off the lower lip on the outer grill piece on the passenger side so that it would fit into the opening.
After you drill out the rivets that hold the stock mounting plates (better have an old grill that has those) I then had to turn the original mounting holes into slots so they would allow the grill to push in far enough to be flush.
Instead of using the rivets right away, I first used some small machine screws to line things up.
Hope some of this makes sense. After market stuff is really an adventure. Looks cool when you are done, but getting there is a real pain in the rear bumper.
Paul
Paul Clark is offline   Reply With Quote
Old 09-17-2002, 09:16 PM   #2
TODDS 72
Not the nightly winner
TODDS 72's Avatar
PAUL
Been there done that ,with the aftermarket goods!!LOL
BUT YOU SAID DRILL/ I THOUGHT IT WAS BRILL? LOL
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
