Active Member
12 Bolt open 3.73 Gear 17 SPLINE
Date coded late 1963
I have the center section- Has 2 broken spider gears- + plus the factory axles These both had been installed in my 68 truck rear end which is date coded late 67. The gears are fine and they are 3.73 gears again date coded 1963 Again this is a 17 spline set up - from what I am told this is rare as hens teeth - you got me as to what everything is worth $40.00 + the ride? Includes 2 axles, center section & ring & pinion Money order or paypal (no credit cards please) Thanks for looking
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
