![]() Join Date: Nov 2006
broke off dipstick tube
well went to check the oil in my newly aquired 72 s.b. and the whole dipstick & TUBE came out...... after looking at the end of the tube i noticed the end was broke off and still down in the block. i dont want to drive it into the oil pan so does anybody have any tricks to remove the stub from the block ? i was thinkin about useing a easy out and try to screw it out. any thoughts guys ?
bob
I BELIEVE IN JOHN 3:16 |
Re: broke off dipstick tube
An easy out should work fine as it shouldn't be to tight in there.
I SURE HOPE SO. i got a new tube and dip stick comming from modern chevy in N.C.
I had one do that to me also. I took a small punch and hit the tube at an angle inbetween the block and the tube.. That way it put a kink in the tube.(that lossened it up) I then took some needle nose pliers put 1 of the needles in on each side of the tube, Squeezed together and twisted. It came right out.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
If the easy out doesn't work, try a big sheet metal screw and a slide hammer or equivelant. Been there done that.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
Dave's not here, man
When mine broke I tried all kinds of things to get it out with no luck. Finally tried to drill it out and the bit grabbed the broken piece and spun it out of the block. Hope yours goes better than mine did.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
good tips......... surely one of these methods will get it out. bugs me alot not havin it right .
thanks again guys bob
All the drilling & stuff would make me a little nervous about getting metal shavings in the oil.
Great minds think alike,So do ours |
I am a Referee of life.
If you think you got even a little filings in it change the oil.If you didn't it probably needs changing anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
no drillin for me. i,ll pull the pan first....... i,am not going to hurt my 383 stroker engine for a dip stick..... i think the big sheet metal screw is the ticket. if i can get it to bite i,am gonna use fender washers and install larger nuts so when screw digs in it will pull tube out. a simple home made puller you might say.
bob
I forgot to mention that I had the pan off when I drilled it out; I couldn't get to it from the top
#13 |
Cause the Chicks DIG IT!!
I did that myself. I just found a bolt that threaded into it aways and then hooked up a slide puller to it and it came right out.
#14 |
just thread a huge screw into it and then you'll have something to pull
