senior member
question about tubular arms
does a drop spindle have to be used with tubular control arms? or is a stock spindle with a drum still useable?
69 GMC bagged |
Re: question about tubular arms
Yes i think it will as long as its got the same balljoint that the drum spindal usees
nickle and dime |
senior member
i assume thye would because most of the things say you can use your original ball joints
69 GMC bagged |
You can use stock or drop spindles on any c-10 tubular control arms.
just watch b/c i've seen some spindles say they only work on disc brakes.
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
