![]() Join Date: Nov 2006
question about lengthening brake pushrod
Hey guys,
Figured I'd wander over to the 67-72 board and get yall's opinions. I recently purchased a MC/Booster combo off a 86-ish 1/2 ton from pull-a-part. I've ran into a problem putting it in my truck though(I know, its not a 67-72, but its the same pedal setup). The pushrod is about an inch too short. I've searched through the threads and saw where others just used coupler nuts. The thing is, my pushrod is non-adjustable. ![]() So what do I do? No access to a welder either. here's a pic similar to my setup(pic courtesy RM72Chevy) thanks in advance |
Re: question about lengthening brake pushrod
The 67-72 rod is made up of two pieces and is approximately 9" long. How long do you need the rod to be?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Designated A-hole!
The one pictured looks just like the one I just put on mine and it's off an 83, but it also is adjustable. The only other way I know of to lengthen it is to cut it and weld a spacer in.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
A tap and die set or even one die with a handle would be a lot cheaper than a welder. I think Sears has these individually. You could cut it and thread the ends about 1". Buy a 2" coupler and get 2 jam nuts from TSC, Lowes, HD, etc. That should get you 0"-1.5" adjustment. I haven't done this but there may be an issue with the angle this rod goes through the firewall. You would want to make sure the collar doesn't catch on anything when the pedal is depressed.
Anyone else know if he should redrill the hole to attach the rod or how close to the pedal arm to put the collar? |
Designated A-hole!
Man is there a high school or junior college near you with a shop or welding class? I bet you could talk someone into welding that for you for free.
