06-23-2007, 11:50 AM | #1 |
3-speed To Auto Questions
Have a 72 long bed c-10, with a three speed on column. What columns will interchange without key switch in the column. No power steering. I would like to find something that column and linkage that will work. I was also wondering about drive shaft length. I will most likely run a th350 long tail shaft. Any suggestions or past problems would be helpful Thanks.
06-23-2007, 12:20 PM | #2 |
Re: 3-speed To Auto Questions
If you run the 350 turbo w/long shaft, you'll have to cut the drive shaft. Try to find a short tail shaft to put on the trans. I believe Chevy/GMC Vans to 1981 columns work but not the shifter linkage, and of course our year trucks, 67/72 auto columns. I went with a Lokar linkage setup.....
1997 GMC Sierra Ext 1965 Mustang |
06-23-2007, 05:03 PM | #3 |
I am a Referee of life.
You will also have to have a crossmember for an auto.An auto column should be fairly easy to find,just be seated if you find a tilt.
BTW Where in NC are ya.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-25-2007, 09:21 AM | #4 |
Thanks for the help and tips.
