1972 C20 Chev
The numbers on my rear axel are 3934635 Can anyone tell me what rear this is? I bought two pinion seals from the auto parts store and they are both too small...
1972 C10 1972 C20 ![]() |
![]() Join Date: Mar 2003
Re: Need help identifying rear end...
Do you have a dana 60 or an eaton ho52? The eaton will have a rear cover that is completely round and would look like a bowl if removed
its all about the +6 inches
Yes, it is the Eaton HO52 it looks like. Are these strong axels?
I come up with a napa number 25970 which fits both the 52 and the 72
Another question... I took the pinion nut off (what a pain) and now I am wondering what torque to put it back on. I have searched the site and have come up with anywhere between 175-400 ft lbs for the ho52. Am I correct in assuming that I can put the nut on 175 lbs and put the cotter pin in and be done with it?
Scott
I was also unaware the nut had to be marked what position it was in, but I have a general idea...am I screwed? Please say no...lol
ttt
![]() Join Date: Jul 2005
no you are not scrd, Re in stall the nut to 175 then mark that spot. with a small punch. Turn the nut additional 1./8 th turn past the mark. Should be about 3-3-1/2 threads out in front of the nut. Ball park figure there. Never seen one of these with a cotter key. May want to set the nut by punching a couple of places around the shaft and nut to keep it from working its way off. or use some locktite. my.02% keep the faith
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Yes, it has a cotter pin. It's set up pretty much like a set of front wheel bearings on a rwd car from what I can tell. Bearing on the inside I can't get to, then one toward the outside, then a washer, castle nut and pin...
in that case turn the nut past the punch mark to the next spot for the insertion of the cotter key.
