Old 06-24-2007, 01:09 AM   #1
OLDIRON69
Intake questions...
I'm getting ready to install a rblt. long block 350 in my '69. What would be a good choice of intake for a fairly stock 350, running ram horns and a Edelbrock 1406? (600 cfm) I do know that.. I tow quite often and the low end torque would be what I'm after. I currently run a stock cast iron with an adaptor.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-24-2007, 01:47 AM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Intake questions...
I have an Edelbrock 2101 on my near-stock rebuilt 350 (flattops, slight cam) with slightly modified Q-jet (larger primaries) and ramhorns. Dunno if it's the best, but it all seems to works well together. It'll be interesting to see what advice you get from those who have tried other combinations...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-24-2007, 02:13 AM   #3
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
I really think a stock intake is good with a combo like yours but the 2101 is a GR8 choice also for just alittle bit more of a kick in the pants.
I am a fan a a stock intake with a little bit of work done to them.
RJ22...
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 06-24-2007, 02:32 AM   #4
bills67
bills67's Avatar
I've got the same carb. on my 350, also have ram horns, the motor is bored
.030 over other than that it's basically stock. I went with the edelbrock performer intake, been running strong ever since.
67 Chevy C-10 LWB Fleet
95 Chevy Silverado Z-71
bills67 is offline   Reply With Quote
Old 06-24-2007, 08:56 AM   #5
eedgell
It's the air up here
eedgell's Avatar
All sound like good choices to me. I would make sure that you stay with a dual plane style. Dont buy a single plane intake for your application.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-24-2007, 09:07 PM   #6
RACINJASON22
GEARHEAD
With the dual plane intake idea whole heartedly, to the point that even on HIGH HP applications now I build all of my engines and recommend dual plane intakes.
Only exception that I make here is on forced induction engines. I.E. nos, blower, turbo ect.
RJ22...
Old 06-25-2007, 07:59 AM   #7
OLDIRON69
I'm sold on the dual plane. I just need to buy it now!
05 2500HD 6.0 excab
Old 06-25-2007, 02:20 PM   #8
OLDIRON69
How about a Weiand Action Plus dual plane? I have ran a Weiand before with good low end torque, but then again the motor was far from stock. I can get the Weiand new in the box for less than $100.00...
05 2500HD 6.0 excab
Old 06-25-2007, 05:13 PM   #9
RACINJASON22
GEARHEAD
The Weiand Action Plus dual plane intake would be a good choice IMO also OLDIRON69. They are a low rise, dual plane design that has a power band from idle to 6000 rpm. So that would fit your needs very nice.
RJ22...
Old 06-25-2007, 07:37 PM   #10
OLDIRON69
Thanks Jason! I grabbed it up and gathering parts for my engine swap, just a rblt 350. I'm just after a little more ump over stock, not much. I recently installed a rblt TH350 and did away with the 3 spd manual. I'm kicking myself for not going with overdrive! Until then, have my Blazer tank,intake,motor swap and disc brakes on the short list.
05 2500HD 6.0 excab
Old 06-25-2007, 07:47 PM   #11
RACINJASON22
GEARHEAD
Sounds good OLDIRON69, I wish I had a "short list"
I have a list but is not short
Yours sounds like it will keep you busy for a while though
RJ22...
Old 06-26-2007, 08:19 AM   #12
OLDIRON69
I just have 2, one short list and one LOOOOONG one!
05 2500HD 6.0 excab
Old 06-26-2007, 01:21 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I replaced my Edelbrock 1406, with the Edelbrock 1901 (maybe the wrong number)....anyway, it's their 750cfm Q-Jet. The previous Edelbrock was running rich... It has .100 main jets and they say it's for performance. The new carburetor ran so much leaner out of the box, that I had to put a heat shield on the starter. Engine runs so much better, even gets better mileage. Starting is much easier, too. I have the carb mounted on the 2101 Performer intake, too.
Member Nr. 2770
