Old 06-24-2007, 01:19 AM   #1
Ricks1971
Ricks1971's Avatar
84 blazer gas tank in 71?
Hey guys there's a guy I know that is parting out a 84 blazer and he said I could have the gas tank if I want. Will this tank off the blazer fit without major modification? Thanks
Ricks1971 is offline   Reply With Quote
Old 06-24-2007, 12:04 PM   #2
sdkid
Re: 84 blazer gas tank in 71?
I think there was a thread awhile back about using a gov surplus gas tank. I think it was around that year.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 06-24-2007, 12:07 PM   #3
sdkid
Here it is. http://67-72chevytrucks.com/vboard/s...d.php?t=234732)
Hope this helps you.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
Old 06-24-2007, 03:53 PM   #4
C.W
Are the suburban tanks the same as the blazer?
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver.
86 Short box just starting the build.
86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come!
98 Cheyenne Ext cab short box 2wd. Driver and maybe future project.
C.W is offline   Reply With Quote
Old 06-24-2007, 04:29 PM   #5
71tahoe
71tahoe's Avatar
Define "major".
71tahoe is offline   Reply With Quote
Old 06-24-2007, 04:34 PM   #6
57sailplane
57sailplane's Avatar
hi,
i did the conversion. using a mid 70's blazer.. i don't think theres much differance in the years but not sure.. make sure its a 20 gallon or less cause i looked at some of the larger suberbon tanks and i dont think they will fit.. oh ya one more thing this is a 84 blazer not s-10 cause i no theres a diferance i think both fit.. i think i saw a thread on the s-10 tank.. anyways good luck..
57sailplane is offline   Reply With Quote
Old 06-25-2007, 12:34 AM   #7
Rokcrln
Rokcrln's Avatar
I have the 25gal 84 blazer tank in Low Buck but it is very tight. I have a leaf spring set up and the tank is against the reciever hitch and I had to bend the tank lip to clear the diff. I do not think it will work with a coil truck because of the pan hard bar.
Rokcrln is offline   Reply With Quote
Old 06-25-2007, 08:21 AM   #8
Mudder
Mudder's Avatar
I have a 33 gallon 85 Blazer tank in my step. I do have a body lift that helps with the filler tube clearence. If you can get the skid plate grab it. I used it to help the two straps hold the tank in place. Here are a few pics.
Mudder is offline   Reply With Quote
