Old 06-24-2007, 07:19 AM   #1
48 ish
48 ish's Avatar
67 dually and rear disc brake conv
I'm planning to convert my 67 C-20 to a dually with disc brakes. Has anyone else done it? Ideally I would use a late model one ton diff with disc brakes already on it. If not I have an idea on how to manufacture the disc brake brackets, has anyone else done that?
hooberjon@yahoo.com
"Life's Been Good To Me So Far"
1941 Chevy PU (new project, right out of the field)
1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor
1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console.
1996 Geo Tracker 2x4
1996 Geo Tracker 4x4
48 ish is offline   Reply With Quote
Old 06-24-2007, 12:45 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Re: 67 dually and rear disc brake conv
Sounds like a great idea...I love the dually flatbeds...just too many projects to start another one now!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-24-2007, 02:16 PM   #3
1969 GMC
1969 GMC's Avatar
I know there is at least one vendor around here who makes disc brake kits expressly for the Eaton axle you should have, but generic 14 bolt brackets can be made to work. Even the generic weld on variety would work.
However, that brings up the problem of parking brakes. I haven't tried Cadillac calipers myself, but have heard they leave quite a bit to be desired on a heavy rig. Late model disc rearends have the parking brake shoes in the rotor hat, if you couldn't find the entire late model axle perhaps you could graft the brakes onto your existing axle.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-24-2007, 04:54 PM   #4
Duallie
Duallie's Avatar
I did it on my '70 C30 carhauler about eight years ago.
I used the stock CC duallie Eaton with duallie hubs, 4x4 F rotors AND backing plates, 4x4 calipers, and a 3.08"-thick (IIRC) spacer to move the rotor inboard from the hub enough for the caliper to clear the duallie wheel. The whole assembly is clamped together with grade8 5/8x6.5" bolts with anti-rotator tabs welded to the bolthead. I tried the Caddy parkbrake calipers, but the won't fit over the rotor(too thick).
In front, I used the BIG rotors and calipers from a 10000lb-tow-capacity 1978 crewcab 2wd C30 and the hydroboost from the same-era truck. I tested a loaded and unloaded panic stop without a proportioning valve and consistently got the fronts to lock before the rears, so I left it unproportioned.
The thing weighs 4100 lbs at each axle unloaded.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 06-24-2007, 05:02 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Wow Duallie! Nice looking car hauler. I have one similiar, but your's looks much nicer than mine. You should post some pics on the "Where are the 1 tons" thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=126946
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-24-2007, 06:10 PM   #6
Duallie
Duallie's Avatar
Well, thanks!!
Check my link out for some pics my brother snapped and made a site out of:
turniptrucking.com
Old 06-24-2007, 11:52 PM   #7
Bob Moore
For info on the rear discs look up member" Drink Too Many " from Spokane. He is associated with Blackbirds Customs or something like that. They manufacture rear disc kits for lots of vehicles. They have a kit for our trucks.
That is a good start for info - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 06-26-2007, 10:40 PM   #8
48 ish
48 ish's Avatar
Thanks all, especially Bob. Anyone know where I can find a dually bed?
hooberjon@yahoo.com
