POA Valve to Orfice Tube?
I did a search and didn't find anything on AC valves. I think my poa valve is messed up on my 72 C10. (keeps freezing up) I have heard you could convert this to an orfice tube set up. I was just wondering what was involved with this change over or has anyone tried it yet.
Thanks |
member #16
![]() Join Date: Dec 1999
Re: POA Valve to Orfice Tube?
Old Air products has a conversion kit.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Spanked once
![]() Join Date: Oct 2006
Here is a good thread and there are is more in the search function.
http://67-72chevytrucks.com/vboard/s...d.php?t=112463 |
That is good info, I have been thinking about doing a conversion to CCOT but had't done any research.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
Thanks for the links Guys.
A new POA Valve cost more than Big Block Accessory Brackets and Tool Box Doors? $325-$625 WOW! |
Old member
There is a cheaper way than that. Go buy a 90's chevy truck acumlator and add it to the system. Put the tube in the bottom line take the dryier out of the system and your done. The fittings can be made at any A/C shop that you need. That's what I did and it works great and a lot cheaper. I just redid the compressor. I bought a aftermarket with the brackets. I have all the factory brakets if anyone needs them for the old comressor.
I need some updated pictures but here is the 2nd revision. Revision 3 pictures will be soon.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 06-25-2007 at 07:31 AM. |
