#1 | |
Bloo
question for the TBI conversion guys
what type of fuel pump are you running?
my truck bogs down bad when i give it gas.. i have a permantly in-line fuel pressure gauge, reads 10PSI key on engine off, 9 psi idle, and drops as low as 5 psi when i start opening the throttle.. stupid Crapa (napa) "10-14 psi" fuel pump ![]() engine specs are: 98 bottem end, stock pistons and rings with 44K miles, crank turned .010/.010, new mains and rods, new t-chain, ported and polished 89 TBI truck heads, stainless steel valves, intake ported, LT1 hydro roller cam, stock ram horns, stock 1990 350 ECM, msd cap, coil, rotor, taylor wires, 2 1/4 exhaust also has new o2 sensor, and plugs
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Re: question for the TBI conversion guys
You can't use a cheapo parts store pump. Holley makes an inline just for this type of application, they are pricey. It needs to be mounted as low & close to the tank as possible. An in- tank pump would be best. Electric pumps don't like to suck, they are made to push.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
Bloo
ive got mine mounted on the frame right where the original rubber line hooks onto the factory carb line.. its about as low and far back to the tank as i can possibly get it..
do you know if Summit carries the fuel pump? |
Well, Whoop-dee-do!
Here's the one I've used before. I think I got it from Summit or Jegs.
http://www.holley.com/12-927.asp
Bloo
looks good to me-- $150ish from summit.. heres the one i was considering:
http://store.summitracing.com/partde...5&autoview=sku heres the holley: http://store.summitracing.com/partde...5&autoview=sku thanks again for your help jeff! |
Active Member
![]() Join Date: Nov 2005
have you thought about plumbing up two cheap-o pumps in parallel with check valves? that way when one fails you can still limp home.
I went fuel cell with an internal factory pump, it's worked great from day one.
Did the pump fail over time or was it that way from the beginning with the cheaper pump? |
Bloo
![]() the reason for all the new parts is because its a new rebuild.. its only been running about a month or two. not drove it down the road yet, but ive jerked around alot of junkers in the feild with it ![]() Last edited by Blue_71; 06-25-2007 at 10:04 PM. |
FORD is a 4 letter word.
Frame mount pump for an 80's Ford P/U with Dual tanks. Common part that you can get at the parts store if it dies. Mine is frame mounted with my tank behind the seat (C10), so it's gravity fed by the tank. I tried in-tank pumps, but without any baffles in the tank, I kept smokin' 'em.
Hope this helps.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project |
