STOLEN
![]() Join Date: Jun 2006
Crossmember Question
I want to replace my crossmember hardware as some are missing and/or in bad shape. The existing are just hex head, no flange with one lock washer. When I replace with Grade 8, should I add flat washers?
In Search Of |
Re: Crossmember Question
I did on the motor and t-case crossmembers...
STOLEN
What length bolt did you replace with?
In Search Of |
I will check tomorrow,I forget.I put them in back in February so I dont remember...... The new grade 8s I used arent much longer than the old ones though...
STOLEN
Thanks Dustin, your build is looking awsome.
In Search Of |
Thanks,the bolts are about 2 and 1/2 inches long,they are a little long but they work...I use a lock washer,and a regular flat washer on it
