Arrived on a Pale Horse
4x4 frame conversion
Can I put a 72 SWB truck body on a 71 Blazer frame? I know it won't be easy, just wondering if things would "bolt up" or what. Wheel bases the same, etc? Thanks.
Jason
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
![]() Join Date: Feb 2001
Re: 4x4 frame conversion
Blazer frames are shorter and would have to be lengthened.
Thanks!
Or put the cab on and shorten the bed...a super short bed!
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
It's the air up here
If you shorten the bed, it's only 4 or 5 inches.. isnt it? It would still look pretty cool, and not hard to do for a body guy.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
do a serch on trazers and you will see a few truck cabs on blazer frames.
Earl 68 2500 4x4 GMC Burb |
huh ???
Here's a couple of Trazer shots...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Active Member
![]() Join Date: Dec 2004
It's more work than you think. I've done it. Cab mounts are different on rear. Need to put 2" body lift or cut out back of lower cab. They do ride nice though. Good luck.........Rick
looks a little goofy imo
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
