Old 06-25-2007, 01:48 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Weekend Wrenchin', What Did You Get Done?
Well, I finally got by the honeydew list and actually got some work done on the projects this weekend.... I had a rear seal leaking on the '67 so I thought it would be a good time to swap rear ends and put the 3.07 in it to replace the 3.73, new brake lines, wheel cylinders, & shoes. The shoes that were on it weren't that old but had a lot of cracks in them. (see pics) Any Idea what would cause that? I think they were the cheaper ones but still shouldn't do that.... Reason for the swap is to drop the RPMs on the 454 and hopefully help the MPG too. I also got the Demon Carb back on the '39 Ford after the factory rebuild (that will be another thread) & put the new stainless grille bars and chrome center bar on it. Looks pretty sharp with them, but I'm not sure it's 300 bucks worth of sharp.. (keeps repeating -It's only money, you can't take it with you..) Now I need to figure out a different way to mount the tranny cooler behind the grille, to make it look better. Anyway....
What did you guys & gals get done?
Leon
Old 06-25-2007, 01:51 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Weekend Wrenchin'
Before I left for GA for the weekend, I was able to get enough of my vintage air kit hooked up so I could fire the truck up for the first time in 3 weeks. I did a big smokey to celebrate (although one wheel is a bit of an embarassment ) Just need to finish the wiring and charge the system
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-26-2007, 02:41 AM   #3
mexgrhd68
mexgrhd68's Avatar
Re: Weekend Wrenchin', What Did You Get Done?
what year cars have that 3.07 rear end, I would love to drop thr RPM's on my 68 chevy truck also. Hate it when RPM's are high and cars are still flying by you.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 06-26-2007, 10:44 AM   #4
LockDoc
LockDoc's Avatar
This one came out of a '70 Chevy Pickup. It had a 350ci motor but I don't remember what tranny. I'll find out.
LockDoc
Leon
Old 06-26-2007, 11:23 AM   #5
Chevelle454
Chevelle454's Avatar
Nice progress... I got my box painted, lights put in, bumper on, rear pinion seal replaced, new trans speedo gears put in, temp sender working and a new steering wheel put on.
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-26-2007, 12:34 PM   #6
mexgrhd68
mexgrhd68's Avatar
LockDoc
Thanks, can't wait to hear back from you.
Old 06-26-2007, 04:40 PM   #7
LockDoc
LockDoc's Avatar
The '70 was a three speed column shift truck.
LockDoc
Leon
Old 06-27-2007, 02:35 AM   #8
mexgrhd68
mexgrhd68's Avatar
LockDoc
are you sure? cause mine was a three on the tree and I'm still using the same rear end. I have a 305 from an 83 monte carlo and a 350 tranny in it now. So could rear ends be different size from factory with 3 speed, I always thought they would be the same size rear end because of the 3 speed tranny. Now as far as what motor mine had I don't know cause when I bought it, it had an old 350 in the bed of the truck and the dude told me that the motor in the bed isn't the stock motor. So therefore, I'm thinking of changing rear end to a 3.07 gear ratio or just installing a 700R4 or maybe do both. What do you think, do both or just either one?
Old 06-27-2007, 08:14 PM   #9
LockDoc
LockDoc's Avatar
Pretty sure, the guy I got the truck from was the second owner, (his mom bought it new). I'd say do what ever you come across first, at a reasonable price. I think the 3.07 would be a little steep with the 700r4 in it...
If you're not sure what ratio your rear axle is there is a code stamped into the axle tube (see pics) and you can go here and look it up in the "axle" section. If your truck originally came with a six cyl it probably would have had a lower geared rear end.
http://www.americanclassic.com/paint.htm
LockDoc
Leon
