Old 06-25-2007, 02:06 PM   #1
Luba
Luba's Avatar
Gas tank??
What are my options for replacing or repairing a stock leaking (slow drips) gas tank on a 72 blazer? I heard the repos are complete junk and have to be made to fit. What is involved in repairing a stock tank? How much? I would rather have a brand new tank but want one that will just bolt in correctly and preferably be made in the usa. Poly or steel?
Luba is offline   Reply With Quote
Old 06-25-2007, 03:13 PM   #2
Luba
Luba's Avatar
Re: Gas tank??
pic
Old 06-25-2007, 05:11 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Gas tank??
I just bought a new tank for my K5 - here is the link http://bowtiebits.com/osc/product_in...oducts_id=1498
I cut off their filler and used a short piece of rubber fuel hose to attach the filler from my existing tank. After doing that it worked just fine. It does come with I think two vent holes that I had soldered shut.
There is a thread maybe 1-2 months ago by Herb101 that has great info on tanks and has some pics of my new tank on the second page.
When I took my old tank in originally to be repaired it turned out too rotten to repair. When I started cleaning that black stuff off the tank there were tons of pin holes spraying out gas.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-25-2007, 05:16 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Gas tank??
Here's the thread.
Old 06-25-2007, 06:36 PM   #5
55dude
55dude's Avatar
Re: Gas tank??
wow! i would have been pissed! that tank must have been over $200 bucks by the time it reached you. you could have made something else fit for a lot less money. we need a forum called "JUNK REPRODUCTION PARTS" to list problems and suppliers and what the supplier is doing to correct the problem. anybody else feel the same?
55dude is offline   Reply With Quote
Old 06-25-2007, 08:42 PM   #6
Luba
Luba's Avatar
Re: Gas tank??
Anyone ever use that gas tank renu process? They blast and coat your old tank and guarantee it for life nationwide. I think I will check into that.
Old 07-04-2007, 02:31 PM   #7
Luba
Luba's Avatar
Re: Gas tank??
Well I took tank to gas tank renu and got a quote. He wants $385 to fix my stock tank! I am not doing that. I think I will try some diy sealers for now.
Old 07-04-2007, 05:55 PM   #8
jamie72
jamie72's Avatar
Re: Gas tank??
i had a slow leak in my tank, i use the por-15 kit for it, cost like 35.00 then, that was like 5yrs ago, no prolbems since.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-05-2007, 04:58 AM   #9
krue
Designated A-hole!
krue's Avatar
Re: Gas tank??
That's what the "Review" board is for.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-12-2007, 04:56 PM   #10
Luba
Luba's Avatar
Re: Gas tank??
UPDATE: I finally got tank sealed up. PO had a couple of patches in there, and one was leaking. I ended up ordering a quart of POR-15's fuel tank sealer. I already have used their paint and I had some of the prep stuff left over. It cost me about $39 shipped for it. It is way better than the $385 the other place wanted to try to seal it. Anyways still letting it dry but I am fairly sure she is good. I coated it both inside and outside and then primed and painted it. Now I am just curious if I can plug 2 of the 5 openings or vents. I just plan to hook up the 2 to the fill hole and one for the fuel sender. The other 2 small side vents I just plan to plug. I am not running the emission crap. Do you think that will be al right? I also assume the 2 vents are the 2 small fittings up top one on each side.
