Old 06-25-2007, 03:18 PM   #1
SkylineNXS
SkylineNXS's Avatar
First start attempt
So after hookin everything up to try and start my 260 I6, i tried to start it, obviously. Im assuming it takes quite a while for fuel to be pumped from the tank to the carb, but how long? After turnin it with the starter for abut 30 seconds however, a little smoke started coming from the front of the motor. I looked and there was a little bit of coolant sitting on the block right below the 90 degree elbow that turns from horizontal to straight up, right where the thermostate is located. Im assuming this gasket is bad where the elbow bolts to the head, so does anyone know where i can get a new gasket for this? Thanks...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 06-25-2007, 03:44 PM   #2
rickf
rickf's Avatar
Re: First start attempt
Almost anyplace that sells aftermarket car parts, they're common as dirt.
Around here, Napa, Schuck's, CarQuest, Baxters, all have them in stock, usually more than one to choose from.
It's a simple gasket, you could buy sheet stock and cut out your own.
rickf is offline   Reply With Quote
Old 06-25-2007, 03:52 PM   #3
hewlett2002000
hewlett2002000's Avatar
when i run mine completely out of gas i put some in the tank and pour a little bit strait in the carb. always works for me. little tip, dont pour it in while somebodies turning it over, i almost blew myself up doing that. and yes i am smarter than that, i dont know what i was thinking. as for the gasket, i put a new one on when i changed my intake and all that and for some reason it still leaked and i think your supposed to do this anyway but i put a little rtv on the gasket and put it back on and solved that problem. hope this helps.
thanks and good luck,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 06-25-2007, 04:18 PM   #4
19GMC63
19GMC63's Avatar
yeah, be sure to use RTV on both sides of the gasket.
As far as fuel, it takes me between 5 to 10 seconds of cranking to get fuel to fill the filter if it was empty. If you don't have a clear inline filter, I would recommend one so you can monitor this.
19GMC63 is offline   Reply With Quote
Old 06-25-2007, 09:13 PM   #5
SkylineNXS
SkylineNXS's Avatar
I dont have an inline filter, and might get one, but i was looking at all the fuel lines after trying for a while, and the main line that goes from the rubber line on the pump to the rubber line right by the cab floor is pretty rusty, at least on the outside. While turning it over, there is no air or anything being pumped out the fuel line right where it goes into the carb, should their be? Other than that, i think i may need some new fuel lines, as mine are pretty shabby lookin. Thanks...
BRAD
