Old 06-25-2007, 04:24 PM   #1
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Probably dumb questions but can I get some help?
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 06-25-2007, 04:34 PM   #2
prg machine
prg machine's Avatar
Re: Probably dumb questions but can I get some help?
water temp sender at the thermostat housing, kinda wierd place for one? I'm not sure. Usualy in the head or manifold.
n As far as the one at firewall,???? I can't tell.
prg machine is offline   Reply With Quote
Old 06-25-2007, 05:04 PM   #3
whatnow123
whatnow123's Avatar
I agree with the first assesment about the temp sender. The second, you asked what that does. Currently nothing... but if it was hooked up, I'm fairly positive that is for the oil pressure gauge.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 06-25-2007, 05:06 PM   #4
jaros44sr
jaros44sr's Avatar
Firewall pic- looks like part of your oil pressure line to the gauge, but you may be missing the line to the back of the block. Are you reading any oil pressure?
Must have been typing at the same time
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-25-2007, 05:07 PM   #5
Imacarguytoo
X2....Wheres the bolt at for the altnernator bracket?
'67 C20 Lwb 350 4-Speed
'01 Chrysler Concorde LXI (wifes ride)
'91 Gmc Suburban 3/4 2wd 454 Tbi
'51 Jeep Cj3a "Willys" 350 V8
Imacarguytoo is offline   Reply With Quote
Old 06-25-2007, 05:16 PM   #6
semperfidoordie
awesome..thanks guys...how do i go about replacing the oil pressure line...cause i don't get any readings on the water temp or oil pressure
Tony
Old 06-25-2007, 07:24 PM   #7
jaros44sr
jaros44sr's Avatar
Check the classified, billsbowtie might have, or various other guys. Saw one not to long ago... J.
That's the great thing about this board, no one seems to mind any questions. You may have a faulty temp. transmitter, there are three other locations you can mount that thingy, if you don't like where its at.... J.
SAFETY FIRST
AS usual, off topic
Jim
Old 06-25-2007, 07:40 PM   #8
LONGHAIR
I would guess that the thermostat housing is off of a later model vehicle. That sending unit is more likely to be a computer sensor that tells it when the engine has "warmed up" because the thermostat has opened. There would probably have been another in the "normal" place in the head, that would have been connected to the gauge/idiot light.
LONGHAIR is offline   Reply With Quote
Old 06-25-2007, 08:34 PM   #9
eedgell
It's the air up here
eedgell's Avatar
The oil line would have to be going to a mechanical gauge inside the cab, not an electronic one, right? Oh and I agree on the bracket bolt.... get one in there.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-25-2007, 09:36 PM   #10
High Speed low Drag
High Speed low Drag's Avatar
Oil line kit available at most good speed shops. (NOT AUTO-ZONE,NAPA, ETC....)
Or summit/jegs.
High Speed low Drag is offline   Reply With Quote
Old 06-26-2007, 08:41 AM   #11
prg machine
Does that mean that Summit or Jegs has em???
Old 06-26-2007, 08:46 AM   #12
kyull67
kyull67's Avatar
I agree. That housing looks Identical to the one on my '81 GMC. I dont think there could be much use for it on your truck.
kyull67 is offline   Reply With Quote
Old 06-26-2007, 08:58 AM   #13
semperfidoordie
so what should i do...get a oil line kit and a new thermostat housing?
Tony
Old 06-26-2007, 10:24 AM   #14
OLDIRON69
You can leave that housing, If you don't mind installing an aftermarket gauge pod with water temp,oil pressure and volt meter, all the necessary fittings will be in the kit. I bought one from the local parts store. My temp sending unit is in the driverside head, up towards the front. Use teflon tape on it when you put it in, same for the oil pressure sender.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-26-2007, 11:26 AM   #15
semperfidoordie
thanks...i'm going to have to try that...just one of those aftermarket ones that mounts to the underside of the dash right? or should i buy the individual guages and mount them in the gauge cluster?
Tony
Old 06-26-2007, 11:39 AM   #16
Frizzle Fry
Frizzle Fry's Avatar
I got a new oil line for the gauge at NAPA. Had to use an adapter fitting at the block though.
Frizzle Fry is offline   Reply With Quote
