06-25-2007, 09:24 PM | #1 |
drive shaft
hey guys can anyone tell me if a one piece driveshaft will hit if the truck is lower 4-1/2in the back it is a short bed fleet coils susp.turbo 400 trans
06-25-2007, 09:25 PM | #2 |
drive shaft
hey guys can anyone tell me if a one piece driveshaft will hit if the truck is lower 4-1/2in the back it is a short bed fleet coils susp.turbo 400 trans if so what so can be done
06-25-2007, 11:35 PM | #3 |
Re: drive shaft
hit what?
06-25-2007, 11:52 PM | #4 |
Dave's not here, man
Re: drive shaft
I put a one-piece in my SWB; it's lowered 5" in the rear. The pillow block where the old center support bearing bolted in had to be cut out, but other than that I had no issues. If you don't already, you'll need an adjustable panhard bar. If the rearend is kicked over to the side your driveshaft may rub where it passes through the crossmember.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
