Old 06-26-2007, 12:19 AM   #1
guf
new delivery! and panel questions
well the pictures are backwards but i got a load of stuff from ece. and now i have tons of work to do. i figure i should start with the rust issues. i searched and found out that i should start from the inside out and cut only the rust out and then trim the panel to fit the section. i started already and have the rocker and part or inner rocker out, should i stop and do the front floor support then move to the inner rocker to outer rocker to pillar to corners. and in the corner where the floor and kick panel hit there is about a inch of rust each one. can i just fill that with scraps in stead of getting whole panels? Can i replace the rubber under the supports now or should that be done later?
guf is offline   Reply With Quote
Old 06-26-2007, 02:34 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: new delivery! and panel questions
I did similar repairs to my 69 Suburban. Here's the link:
http://67-72chevytrucks.com/vboard/s...=200387&page=2
Hart_Rod is offline   Reply With Quote
Old 06-26-2007, 06:48 AM   #3
jaros44sr
jaros44sr's Avatar
If you get rid of the lower 'A' post you will have better access to the kick panel, since you have to repair it anyway. The kick panel patch has lots of bends in it, so unless you are really good at fabrication, I'd say buy the patch... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
