Old 06-26-2007, 04:21 PM   #1
stunna
Question serpentine systems
Does anyone know what the major advantages of having a 1 belt serpentine system vs a 2 belt system besides the look, and are there any good priced systems out there that don't cost an arm and a leg.
stunna is offline   Reply With Quote
Old 06-26-2007, 04:49 PM   #2
Ackattack
Ackattack's Avatar
Re: serpentine systems
the advantage that I've noticed is most of them don't requuire removing the fan to put the belt on. Also, most of them have a spring loaded idler pully so you don't have to mess with adjusting the tension on them
I think the TPI camaro/corvette v8 engines started using serpentine systems in 88. I would assume that the truck v8 and 4.3L v6 also started using them about the same time.
I know my 97 Tahoe had a serp. setup.
Ackattack is offline   Reply With Quote
Old 06-26-2007, 06:05 PM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
GMPP sells a pretty reasonably priced kit.
12497697 no A/C GM list 701.00
12497698 with A/C GM list 964.00
I think you can buy them through Jegs a little cheaper.
12497698 through Jegs is 759.99
http://www.jegs.com/webapp/wcs/store...10002_94398_-1
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-26-2007, 06:09 PM   #4
Rust Buster
Rust Buster's Avatar
Yeah, the GMPP system looks pretty good, you get the water pump, alternator, A/C compressor and PS pump with all the idlers and pulleys for around $800...
Will the A/C compressor be a plug and play for the 67-72 A/C systems though?
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 06-26-2007, 06:15 PM   #5
BACKYARD88
BACKYARD88's Avatar
The GMPP kit comes with a R4 style compressor that mounts on the passengers side. I'd imagine you'd have to get some hoses made and probably purchase a few connectors to take care of the electrical portion.
Edit: The kit comes with a connector but I'm not sure if it's for the alternator or compressor.
-Mike Owen-
Old 06-26-2007, 07:36 PM   #6
pcmcobra
pcmcobra's Avatar
Try ebay. I got mine "less" water pump for $150. Water pump was $35 at oreilly's.
I'm glad I did the conversion. Will make it easier if you have to remove an accessory or the belt. On my 86 the 88-92 iroc/firebird ac lines are supposed to bolt right up, I heard 89-91 blazer ac lines will also. I am on the hunt for some ac lines, the ones I got with my setup were not correct.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-26-2007, 07:49 PM   #7
TN70C10
go to the junk yard and get the setup for 50 bucks then you can take you 800 put a few hundred more with it and have a set of aluminum heads. no way i would pay 800 for serpintine when you can get heads for about the same price.
TN70C10 is offline   Reply With Quote
Old 06-27-2007, 12:46 AM   #8
randomhero472
randomhero472's Avatar
i've read where people have been robbing them off junk yard cars.. for next to nothing, somthing to check into for sure
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-27-2007, 01:01 AM   #9
65-72 chevytoys
65-72 chevytoys's Avatar
junkyard is the way to go clean and repaint and save yourself $700
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 06-27-2007, 08:38 AM   #10
BACKYARD88
BACKYARD88's Avatar
If you want to go the junkyard route you can use the parts off of 4.3 V6 out of s-10s and astro vans and 4.3, 5.0, & 5.7 out of fullsize trucks. There are a few different designs but they will all work just cut off the electrical connectors in case you need them. Some other models will work too but these are the most common.
-Mike Owen-
Old 06-27-2007, 09:04 AM   #11
lofly'a
lofly'a's Avatar
words of advice, based on experience. the serpentine system is far superior as far as service and service life, but if you do the conversion try to get the cast aluminum bracket system and use all of it. if you use the stamped steel one piece system use all the brackets and braces that came with it (and there are quite a few) because those are prone to vibration/stress cracks. i've welded quite a few steel ones back together that have cracked and or broken off, (this usually causes other heartaches too) mostly because someone worked on the engine and did'nt put all the bolts back in or did'nt tighten them. the beauty of this system is one belt, a lot quieter than a v-belt setup, you'll get at least 100k miles before any parts wear out, and you can carry a spare belt in a very small place.......... and you only need one wrench to change it out. go for it.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 06-27-2007, 09:11 AM   #12
BACKYARD88
BACKYARD88's Avatar
Good point. The style that has the big "horseshoe" bracket and the other steel ones are prone to cracking especially at the alternator mounting points. Make sure and use all of the braces.
-Mike Owen-
Old 06-27-2007, 10:17 AM   #13
Zoomad75
K5Camper
Zoomad75's Avatar
Here's the mother of all serpentine threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=233335
3 pages of good info there.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 06-27-2007, 12:46 PM   #14
Jonce
Jonce's Avatar
I have the GMPP serpentine on my GMPP crate motor (came from an older engine with v-belt setup). I love this one belt system, seems to be the first thing people notice when I lift the hood.
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 06-27-2007, 02:04 PM   #15
stunna
guys thanks for all of this valuable information, you guys are soooo smart!!
