#1 | |||
Union Electrician
How low can I go using drop spindles and springs only without modding the inner fenders or tire rub issues. Wheels that are possiblly using are 20x8.5 (4.5 or5 backspacing)in the front. TIA ...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
A guy with a truck
Re: static drop w/20's
As low as you want. I would not do more than 3" springs 'cause it won't align. Go with at least 5.25 BS for a 8.5" wheel so that the wheel 'tucks' in a little; that will keep you from rubbing when you hit a bump.
I have done exactly this with a 255/70-15 which is the exact same as a 255/45-20 (29" tall). It could easily go another inch with no problems... -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Truck Enthusiast
do you have truck arms in the rear? im running a 20x8.5 and 20x10 both with 4.5" of bs. no probs at all and im lowered 4.5/7. im also running an adjustable panhard bar to center the rear after i lowered it. tires are 255/40 and 295/40
pics http://67-72chevytrucks.com/vboard/s...d.php?t=244913
'85 swb Last edited by droppedgmc; 06-27-2007 at 12:22 AM. |
