Old 06-26-2007, 09:51 PM   #1
goldengoat2
early 70's large hub look
I'm installing 77 3/4 axles in my 67 3/4 ton but the hubs don't look as big diameter as the earlyer 70's year hubs , will the early hubs fit on thes axles (if I find some in the future), I like the beefier look of the early 70's, thanks.
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 06-26-2007, 10:25 PM   #2
msgross
msgross's Avatar
Re: early 70's large hub look
the 67 was closed knuckle, right? If so then I doubt it.... Put a dana60 under it and you might be good...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-26-2007, 10:48 PM   #3
The chrome-rimmed/blue centered lock-outs were used from 69-75 and won`t fit those axles/hubs.
Old 06-26-2007, 11:05 PM   #4
CrashEd
72 chevy
CrashEd's Avatar
You would have to change out the spindel and the out side shaft but it will bolt to the newer knuckel.
Ed
CrashEd is offline   Reply With Quote
Old 06-26-2007, 11:47 PM   #5
eedgell
It's the air up here
eedgell's Avatar
Your talking about the large spicer hub, right?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-27-2007, 12:21 AM   #6
CrashEd
72 chevy
CrashEd's Avatar
I think he is talking about going from internal to external lockouts and wanting to change it all from the knuckel out if he finds some.
Ed
Old 06-27-2007, 06:36 AM   #7
Blazer1970
Blazer1970's Avatar
The smaller internal style lockouts that were used on open knuckle half tons and all later model axles are a much better stronger design than the old (bigger) external style. The internal lockouts transfer the power from the shaft to the wheel hub through a set of internal splines in the wheel hub. The external style transfer the power through the bolts that hold the lockout to the wheel hub and have a problem with the bolts coming loose.
Blazer1970 is offline   Reply With Quote
Old 06-27-2007, 07:36 AM   #8
Hmmm....never had that problem in over 30 years.Heard about it,though.
Old 06-27-2007, 08:25 AM   #9
va_tlc
va_tlc's Avatar
not sure if you can read this but it spells,FER...D LOL i gotta cover that up somehows huh
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 06-27-2007, 04:57 PM   #10
Peel it off.It`s just foil.
Old 06-27-2007, 07:56 PM   #11
goldengoat2
Yes, I like the 69 to 75 look, with the crome rim like va tlc's picture. I just got my $325.00 3/4 ton parts truck home (1977), for my 67 3/4 ton.I will use these axles for now because I need to get rid of these closed knuckle axles. But I will still look for the 3/4 ton 71 to 75 axles with disc brakes. thanks everybody.
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
