Old 06-27-2007, 01:26 AM   #1
cell
Active Member
cell's Avatar
anyone used an electric radiator fan from ebay? (procomp 16")
Hey guys,
Last time I looked into electric radiator fans I seem to remember them being too expensive (~$100).
However, I just noticed on ebay that a Procomp 16" fan is only $25.
Anybody have any luck with these? If not, I'll give it a go and report back with my experience.
cell is offline   Reply With Quote
Old 06-27-2007, 01:49 AM   #2
David Flores
David Flores's Avatar
Re: anyone used an electric radiator fan from ebay? (procomp 16")
Not sure, but the procomp fans on ebay are only 1250 cfm.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 06-27-2007, 02:40 AM   #3
cameeks
Long Fleet Club
cameeks's Avatar
they are listed at 2500 cfm
I'm thinking about looking at those later now
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 06-27-2007, 05:46 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
if its one alone then put 2 of them on and you should be fine
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-27-2007, 10:43 AM   #5
cell
Active Member
cell's Avatar
yeah, not sure if i want a single 16" or double 10" fans. I must admit the systems administrator (computer geek) in me wants fault tolerance just for the sake of it
Old 06-27-2007, 11:02 AM   #6
cameeks
Long Fleet Club
cameeks's Avatar
Do you think 2 12 inch fans would work?
Chris Meeks
Old 06-27-2007, 07:58 PM   #7
mnunn454
mnunn454's Avatar
A couple of thoughts from someone who's considering going with electric fans but hasn't done so yet:
Will you need an alternator upgrade to handle the extra amps?
Is there sufficient clearance between the water pump and radiator?
Have you priced all the fan controls/relays.
You will be using a fan shroud, won't you?
Suggest not mounting the fan using the nylon ties that go through the radiator fins (front to back). Fan startup torque sometimes twists the unit and causes holes in the radiator tubes. Use an external bracket or shroud to mount the fan(s).
Do you have A/C? If yes, then I'd suggest using 2 "puller" fans, each with it's own thermostat. If you have a 185 degree thermostat inside the engine, set one of the fan thermostats for about 195 degrees, the other for about 205 degrees and make they both come on when the AC compressor kicks on.
I think I read puller fans are a little (10-15%) more efficient than pusher fans, moreso if you use a fan shroud. So if you decide to "push", buy them bigger, then reconsider question #1.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 06-27-2007, 08:20 PM   #8
Pete6960
Pete6960's Avatar
Cheaper Is Not Always Better...........
Pete6960 is offline   Reply With Quote
Old 06-28-2007, 01:17 AM   #9
cameeks
Long Fleet Club
cameeks's Avatar
I had a 16" procomp that I bought from a friend for $5 and I used it for over 2 years until I striped the car. Sold it to a friend and he has been using it for 3 years now with no problems. Note this is with no fan shroud and a constant on power from the key. I bought 2 of the 14" and going to fab up a shroud. For temp I'm going to wire it up the same way until I get some extra cash and decide what kind of switch I want to get. But I guess it is always easier to say cost more must be better.
Chris Meeks
Old 06-28-2007, 10:44 AM   #10
cell
Active Member
cell's Avatar
thanks for the tips guys. as for the shroud, i just finished up a welding course at the local community college, so I'll be (attempting to) fab up my own shroud as well.
Old 06-28-2007, 12:39 PM   #11
randomhero472
randomhero472's Avatar
wheres a good place to find a fan shround, and also anyone here fab up a shroud-fan combo?
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
