Old 09-18-2002, 01:55 PM   #1
busterwivell
Tach problems
Anyone know why my tach would work accurately sometimes, and be way off others? Is it just screwed up, or is there something I can do to make it accurate all the time. 55 MPH is 3000 RPM, normally. Sometimes, though, it's more like 4000 RPM. Would rather fix than replace, if I can.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 09-18-2002, 01:58 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Is this a stock tach? Sounds like it is a loose connection. I would check to see if you have all the connections tight. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-18-2002, 02:01 PM   #3
busterwivell
Yah, factory in-dash tach
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 09-18-2002, 02:34 PM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Are you running HEI or the old points.The orig. tach was designed with the points in mind.
A filter can be made and placed "inline" on the tach wire.This will help with the erroneous readings.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-18-2002, 03:50 PM   #5
palallin
OK, my high school electronics shop is a long way behind me: can someone interpret the schematic for me?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 09-18-2002, 04:17 PM   #6
busterwivell
I have an HEI. I don't understand the schematic (I'm old). Where can I get a filter? just connect it in the HEI wire for the tach? Thanks!
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 09-18-2002, 05:09 PM   #7
Michael A. K. G
That's a double low pass filter, one with a pass at 12 Hz and the other at 1 MHz. The right one isn't going to do anything; the signal it gets will already be smoothed at such high frequencies.
Why did you put in the second filter?
Michael A. K. G is offline   Reply With Quote
Old 09-18-2002, 05:22 PM   #8
red71cheyenne
Back in the sticks
You dont' need the filter. I run a factory tach with my Tune Port and have never had a problem. Just hook it up to the tach pin on the distributor and run the power lead to a pink wire. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 09-18-2002, 06:05 PM   #9
Stout72
Not my good side.
Stout72's Avatar
Busterwivell, mine does that, too. Factory tach, it seems to indicate approx 800 rpm higher when it's cold outside (like on the way in to work) compared to when it's warm out (like on the way home). I'm also running HEI, no filter. Was a bit curious about why.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 09-18-2002, 08:08 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Its becouse tehy were not acurate 30 years ago, and they are getting worse with age.
Old 09-19-2002, 04:12 AM   #11
BobbyK
BobbyK's Avatar
The tach schematic was posted on another board(coloradok5.com) that's where I stole it from.
I personally don't have a filter with my factory tach and don't have any problems( I run a G.M. TPI unit as well).
I know guys have problems with factory tach's and HEI.I heard it's has something to do with the shape of the wavelength in the HEI signal.I think,don't quote me though,the HEI signal is square where-as the points signal is more round.I think that is why the factory tach has problems with the HEI signal.
Plus,as longhornmail has stated,the built-in inaccuracey of the factory tach's,along with age could have something to do with it.
I believe the filter rounds off the HEI signal so it's looks more like a points signal to the tach.
Old 09-19-2002, 06:09 PM   #12
busterwivell
Anyone with a factory tach and an HEI that's NOT having a problem, and if so, did you do something we should do?
Bill - Tucson, AZ
01 Chevrolet Tahoe
Old 09-19-2002, 07:36 PM   #13
Gene
Gene's Avatar
I am running a factory tach. and a GM HEI. Ran a wire to the tach side of the distributor, and the other(red wire) to the fuse box, plugged it into a spare lead. Oh, are you using a factory wiring harness from a tach. truck? Mine was a used tach. dash and it came with the wiring harness with it. The wires are pretty heavy guage i'd say 10 gauge at least they are almost 1/4 inch diameter. Maybe your wires are too small for the tach. to work right? I dunno just a guess...
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
