06-27-2007, 10:00 AM | #1 |
72 Chevy K10 wheel fitment
Hi All! I have a stock 72 K10. I bought some 6 bolt 1987 factory rally wheels off ebay-will they fit my 72 without modification?
Thanks Tony |
06-27-2007, 12:23 PM | #2 |
Re: 72 Chevy K10 wheel fitment
Good looking truck! And more pics or info on it?
And yes, Rally wheels will bolt right on!!
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
06-27-2007, 12:53 PM | #3 |
Yeah, I bought this truck from the original owner. It is totally stock! Literally every single original part is on it. Still has original shocks, u-joints and exhuast, never lifted and no holes drilled in it anywhere. It has 97,000 miles on it. Had car tires on it when I got it-so it was'nt off roaded. PS, PB and Factory A/C. Never seen anything survive in such condition, especially a 4x4 truck! Tony
06-27-2007, 12:56 PM | #4 |
Welcome to the board and nice truck!! Be sure to post a pic in the 4wd Section in the Post Your 4x4 Pic Thread.Personally,I think the truck would look good with a 2" lift and some 33s on rally wheels.Maybe add a chrome sport bumper on the rear too..but that's just me..
06-27-2007, 12:59 PM | #5 |
Nice truck!!
Do what ever YOU want to do!! |
06-27-2007, 12:59 PM | #6 |
Here is the trouble. I have the wheels-bolt holes line up perfectly, trouble is they are really tight fitting over the axle shaft where the center hole fits over. I think I could crank the wheels on with the lugnuts but then they might never come back off. What should I do? Do I have to grind the hole out larger. Seems like the hole is very close to fitting but just too tight. Thanks for any help. Tony
06-27-2007, 01:00 PM | #7 |
What are your plans for it?
06-27-2007, 01:02 PM | #8 |
It should be a sort of a tight fit..load is on the hub,not the studs for the lugnuts.If they are off a 4wd,they should work.Sometimes I just have to spin the rim around and push in and it goes on.
06-27-2007, 01:05 PM | #9 |
STOLEN
Sometimes the centers will bind and have to be hit with a die grinder. Mine were almost impossible to get off when I redid the ball joints. Would not want that to happen if I had a flat on the side of the road.
In Search Of Last edited by 67CHIP72; 06-27-2007 at 01:08 PM. Reason: typo |
06-27-2007, 01:20 PM | #10 |
Plan for the truck is to leave it as stock as possible since it is so rare to see one like this. So I will put rally wheels on it with BFG 31x10.50x15, leave it stock ride height. In the future I may replace the engine with a factory GM 290 HP 350 crate motor. I would like to install the Edelbrock multiport fuel injection system on it someday. Thing is the truck is so damn stock I hate to touch it at all, but they were ment to be used and enjoyed right? Tony
06-27-2007, 01:24 PM | #11 |
As far as the wheels go the die grinder idea sounds good. I just wanted to make sure that these wheels were supposed to fit the truck! Anymore advice would be appreciated. Thanks Tony
06-27-2007, 01:40 PM | #12 |
I make Models
Here is a pic of my truck with GM White spokes....truck is stock suspension w/33" tires.....your rally's should fit the same as these......if you are going to die grind the hole he is only talking about grinding the center hole where it goes over the hub.....you should not grind the stud holes in anyway.....Good Luck with the truck......
06-27-2007, 02:50 PM | #13 |
Nice looking truck you got there! I like the chrome center caps, makes the wheels really look nice. Tony
06-27-2007, 03:08 PM | #14 |
Aluminum slot wheels rule...
Tony, your truck looks like it just rolled off the production line. That thing looks nice!
Should look even better with rallys and 31's. |
06-27-2007, 04:27 PM | #15 |
The part that will make you sick is that I payed only $3,500 for it!!! Gotta have some good luck once in a while!
