Holley TBI
Went camping this weekend and determined in the hills that I really need to go with a TBI or some sort of EFI because of the hiccups in the elevation. I have an opportunity to pick up a Holley Pro-Jection 2bbl system off of a guy on craigslist for a steal. However, on Holley's website, it specifies that the Pro-Jection kit P/N 502-20S is only good up to 275HP. I'm running a crate motor in the 72 that is the newer style with the center valve cover bolts that is supposed to be putting out 300HP. Realistically, I'm sure that this engine isn't putting out 300, however I'm concerned that it is not enough for my motor. Any of you guys have any experience with this? Should I step up for a larger unit that is rated for higher horses? BTW, here are a couple of pics of our camping trip this weekend, it was perfect weather and great opportunity to get out of the heat for the weekend, enjoy.
![]() Join Date: May 2005
Re: Holley TBI
Love your Blazer, haven't seen it on here before. Sorry I can't help you with your tech question, but i'm sure someone here will help you out.
Cheers, Pete |
Oh..never mind....
Re: Holley TBI
The Holly Pro-Jection units that I know of end up getting taken off. They tend to run lean and have burned up a few engines around here. If you want to put one on, then really consider to bigger unit to help avoid the lean out issue. I know that it might look like a good deal, but it is getting pulled off another reason, and it is not a good deal to have a fried motor. I would look at some of the after market TBI units that use Chevy parts. They are much more reliable and somewhat easier to get parts for if something goes wrong. A few place will even custom build the unit to your application.
1972 Blazer -6 inch lift -35 inch BFG A/T's Turbo 350 NP-205 454 BB (for now) MORE TO COME !!!!!! Now going to 2WD!!!!! Sold. ![]() ![]() ![]() I got it back after 22 years and did not even know it !!! THE STORY HERE Project Low Down Dirty Rat |
Post Whore
![]() Join Date: Feb 2000
Re: Holley TBI
Just wanted to chime in and also compliment you on your K5 - beautiful rig!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: Holley TBI
Thanks for the compliments. It was pretty straight to begin with, being an original AZ truck. I'm the third owner, and so far I've stripped it and painted it with absolutely ZERO filler, and I also painted the top with advice from another member. Anway, It's a nice 10 foot paint job (my first attempt at a complete job). I also found a Commander 950 4BBL TBI kit that a guy is getting rid of but that looks like it's quite a bit more intensive to tune and you have to have a laptop to get it all dialed in. Anyone ever had experience with the Howell kits on a SBC?
Re: Holley TBI
IMO do a chevy TBI, super simple and faily cheap.
Re: Holley TBI
VT, what application would you suggest? I know there have been a couple write-ups but the only ones I've seen they pulled the motor as well. Is there a late model application that would bolt on to the motor I've got without having to completely re-wire? BTW, I re-painted mine the medium olive with the white top after seeing the write up of yours.
Re: Holley TBI
Check out the "Fuel Injection Section" over on CK5, tons of great info there.
The last two I got were from truck boards, keep your eyes open and they come up with some regularity and the price is normally pretty good. Get as much as possible: *Computer (very important) *Manifold, injectors and as many sensors as you can. Will need an O2 sensor too. An electric fuel pump will be needed also. You could go either in-line or internal in the tank. (even use the stock tank) http://www.tanksinc.com/cartimages/page_lg_24.jpg Then comes the wiring. I find it easier to buy an after market harness, just saves time and frustration. Cool on the repaint, post a pic. ![]() |
Re: Holley TBI
This might be what you are looking for:
http://www.mass-floefi.com/QandA.htm
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#10 | |
Blazerless
Re: Holley TBI
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD ![]() 69' Beaumont 388/700R4 11.70@116 ![]() 77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad. |
