06-27-2007, 01:29 PM | #1 |
column shift for 700R4
I have had a floor shifter for some time, but would like to go back to a column shift.
Can you make a column shifter work with all 4 gears of a 700R4? Also, can you get a new indicator that shows 4 positions and looks factory? |
06-27-2007, 01:35 PM | #2 |
Re: column shift for 700R4
Yes & yes.
I used a Lokar shift linkage for mine, but I think you can modify stock linkage to work. I got my indicator from the Truck & Car Shop.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
06-27-2007, 01:42 PM | #3 |
that is where i got mine too, i think they are on sale,showed $7 on site and in the cart they were $4 so i bought 2!
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
06-27-2007, 02:12 PM | #4 |
Active Member
i changed the whole steering column out of the truck i got my tranny out of
i got everything out of the same truck and changed it to tilt wheels also was able to put my wiper on/off switch on the column and also hooked up cruise control to so find your self a truck that has the whole setup and get it all |
06-27-2007, 03:13 PM | #5 | |
06-27-2007, 04:13 PM | #6 |
Parts and more parts
I took my GM column shift and linkage and made it workwith a 700R4 without a lot of work. Let the tranny detents do your work for you and install the plastic OD shift indicator and all is well. Be sure to align the shift points with the different detents.
06-27-2007, 04:17 PM | #7 |
That's all I did. I just loosened the linkage and adjusted it to line it up with the detents. I also mooved the linkage pivit pin down on the frame back to line up with the linkage on the transmission. I haven't bothered to change the indicator. It lines up with drive when it is in overdrive. L1 drops down below L1 on the indicator.
06-27-2007, 04:59 PM | #8 |
Ok, sounds good. Good to know that it's easily posible.
I took the column shifter off about 5 years ago and the parts are long gone, but I got another column I can use. |
06-28-2007, 09:49 AM | #9 |
How about a link for the Truck and Car shop???
06-28-2007, 10:58 AM | #10 |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
06-28-2007, 11:56 AM | #11 |
Licensed to Thrill!
I bought one of these:
http://cgi.ebay.com/ebaymotors/POLIS...temZ8035133062 Looks really nice. I would recommend it. DLB |
