Old 06-27-2007, 03:49 PM   #1
itsmike2k
compressor, tanks and valve placement
Lets see some pictures of where everyone mounted their air system.. I'm trying to decide what to go with, 2 or 1 tank and where to mount it, the compressors and valves. thanks
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 06-28-2007, 08:11 PM   #2
randomhero472
randomhero472's Avatar
Re: compressor, tanks and valve placement
majority of people mount the airtank and compressor on the frame rails, valves too
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-28-2007, 09:13 PM   #3
Shane
Shane's Avatar
mine will be going in the bed ...
Shane is offline   Reply With Quote
Old 06-28-2007, 11:41 PM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Here's my setup. Works great. I'm moving my water trap up and out of the way since I'll be a lot lower with the step notch and sectioned x-member.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 06-29-2007, 09:37 AM   #5
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
here's my setup:
IvelDesigns is offline   Reply With Quote
Old 06-29-2007, 11:07 AM   #6
itsmike2k
What size tank and compressor? How does the single compressor work for you, Like fill up time? Is there enough capacity to raise all 4 from the tank? Thanks
Mike
Old 06-29-2007, 11:24 AM   #7
Frizzle Fry
Frizzle Fry's Avatar
Just finished installing mine. Bags this weekend!
I put a 5 gal tank behind the rear-most crossmember. Not sure if I've seen anyone put one there before, but it works out really well for space and tucks up nicely. The comp is a Viair-380. This is on my Tahoe (Suburban frame cut down to SWB dimensions) so I can't guarantee it would work for a truck. Here's my set-up:
Frizzle Fry is offline   Reply With Quote
Old 06-29-2007, 12:17 PM   #8
IvelDesigns
i used a vlair 460 and 5 gal 8 port tank. with the tank holding 145psi, and the bags empty, i can get the fronts to about 95psi and the rears to around 60.
leaving about 60psi in the tank.
95 psi up front allows me to have about 5" of space between the tire and the fender lip. that's with 2.5" drop spindles.
i usually ride at 78psi up front and 55psi in the back. I have not taken the time to find the optimal ride height/psi yet, so those will probably change.
with the tank holding 60psi or so, it takes 2-3 min to get up to 145.
Old 06-29-2007, 12:19 PM   #9
IvelDesigns
oh, and i'm using 1/2" line from the compressor to the tank, and 3/8 from the tank to the bags. 1/4 from the bags to the gauges.
i'm happy with the speed that they fill when the tank has 145psi in it. fronts come up in about 1.5 seconds, and the rears in about 1. when i drop it, it does not slam down. takes about 1 sec to drop everything.
Old 06-29-2007, 03:08 PM   #10
itsmike2k
Looks nice Frizzle. Wont work for me thought because of my gas tank. atleat i dont think it will. I have a custom tank and had to take out my rear xmember to get it to fit...
I was thinking about going with a single 480 and a 5 gal tank and then ad another compressor and tank before i finish if i need it.. I'll probably start by putting everything on the driver frame rail..
Mike
Old 06-29-2007, 05:28 PM   #11
randomhero472
could somebody give me the the measurment for in between the frame rails, preferably back where the rear xmember is, i've seen a long-skinny 6-8 gallon tank, i figure you could take out that rear xmember and weld in a smaller support and have enough room for a large air tank.. also anyone have a measurment from the back of the blazer tank to the end of the frame?
edti: im not being lazy, my truck is 500 miles away @ the body guy
Old 06-29-2007, 06:52 PM   #12
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
The frame measurement is 27.5" from the inside lower "[" channel to the other side's inside lower "]" channel. AKA largest box you could slide between the rails from the bottom.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 07-01-2007, 12:42 PM   #13
randomhero472
can anyone confirm that a 5 gallon tank would fit either on the frame, either in front or behind the rear wheel, or would it fit behind the last crossmember on the frame, if the truck had a roll pan.. ??
Old 07-01-2007, 03:42 PM   #14
Frizzle Fry
Mine should be the same dimensions as a SWB frame but I have not confirmed that 100%... I can tell you that I had to trim both the rear crossmember that it's mounted to and the rear cross-sill to get it in there nice and high. I expect you would have to do the same on a SWB truck.
Old 07-02-2007, 12:24 AM   #15
MEANGREEN70
MEANGREEN70's Avatar
Heres pics of my setup.
MEANGREEN70 is offline   Reply With Quote
Old 07-02-2007, 09:48 AM   #16
randomhero472
nice setup meangreen.. where did you get those tanks at... and also what valves are you using, any issues or advice on anything?
Old 07-02-2007, 11:17 AM   #17
itsmike2k
Looks good Meangreen!! I cant decide if i want to go in front or behind the rear tires.. Anyone have any measurements on a fleetside, like how far over the frame does the bed sides drop and what is the distance between the inner bedsides and the frame? Thanks
Mike
Old 07-02-2007, 12:59 PM   #18
MEANGREEN70
Thanks guys, randomneroa I got the tanks and the valves from fbirides.com
I bought a complete kit from then, the only thing that I dont like from the kit is the comp are not that good. So i'm getting differnet ones. the valve are blihzluft 1/2 valves, I dont know much about then.
the only advice that i can give, is take your time and do lots of reserch. The guys in here have been very helpful to me.
Good luck and let me know if i can help you with anything else.
Old 07-02-2007, 01:38 PM   #19
Kontrol Phreaks
Kontrol Phreaks's Avatar
Here are some images of various C10 truck that I have built with all kinds of different air management configurations. Hopefully they will give you some ideas to go off of when you start your project. You can always contact me if you have any questions about any of these projects / pictures.
This truck has (1) 3 gallon air tank and (1) 5 gallon air tank behind the axle. Was filled by (2) 460 Compressors on the outside of the frame rail. Valves were mounted inside the frame up under the cab with the lines running inside the frame rails.
This truck has (1) 5 gallon tank behind the axle with (1) 460 Compressor mounted right behind it. Valves mounted on 2 bolt-on alumn. mounting plates just behind the compressor on the factory rear cross member. Front valves were outside the frame under the cab.
This truck has (4) 3 gallon tanks linked inside the rear frame rails. Filled by (3) 380 Compressors on the outside of the frame rails with (1) 85 amp solenoid mounted there to control the compressors as well.
Another look at the compressors and tanks on the same truck.
This truck has (2) 5 gallon multi-port tanks with the valves mounted off them including all the digital senders for the gauge. Also has (2) 450 Compressors mounted on the outside of the frame rails.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 07-02-2007, 02:15 PM   #20
Kontrol Phreaks
You could probably fit a 5 thin gallon tank on the outside of the frame behind the axle. Our tanks are 8" dia. X 25" long. They have bottom mounted legs which you could bolt to a drop down bracket off the frame. I know you could get a 3 gallon tank on each corner with no problem and link them together to get you 6 gallons total. Just an idea.
I don't think there is enough room to run a tank off the back side of the rear most crossmember.
- Clint -
Old 07-02-2007, 03:54 PM   #21
itsmike2k
Those look good!! I think i have to go on the frame rails with my tank(s) and compressor(s) because of my gas tank and i'm not going low enough to raise the floor of the bed.. I'm leaning towards a 5gal stainless tank and a 480 to start....
Mike
Old 07-02-2007, 08:10 PM   #22
Kontrol Phreaks
Let me know when you're ready to get the tank and compressor. We have those in stock and I can give you the forum membership discount with honest shipping charges.
- Clint -
Old 07-03-2007, 10:14 AM   #23
itsmike2k
Thanks and I'll check prices with you on some other stuff but i already ordered my 480c.. Got it for $180.00 to my door which seems like a great price compared to some places that want close to 250.00.. Do you have any 5 gal stainless tanks? thanks
Mike
