Old 06-27-2007, 04:43 PM   #1
mcarrel
Ideas best battery location custom 57?
I am working on my wiring and I am trying to decide the best place to locate the battery on my 57 Custom project. I figure there are different opinions but with the wealth of experience here in this forum I figure I would ask. I want everything under the hood clean no battery and minimal wires showing. I am mounting the ECM for the TPI under the passenger seat and all the relays are going in the back corner behind the passenger seat. Here are some of my thoughts any comments or new ideas appreciated I am thinking I will use an Optima battery.
1. Behind the passenger seat (very crampt)
2. Under the truck between the frame and the left step. (Not very accessable)
3. Under the bed front right corner. Will have to build an access door.
4. other ideas?
mcarrel is offline   Reply With Quote
Old 06-27-2007, 05:06 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Ideas best battery location custom 57?
I'd put it on the frame behind the step. Get a s/s drop down box from Brothers or build your own set up.
Truck looks good. Any more pics?
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-27-2007, 05:20 PM   #3
1lowdiesel
1lowdiesel's Avatar
how much room do you have up under the dash? if you go with an optima you can mount it upside down.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-28-2007, 10:04 AM   #4
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Brian ...
+1
mine is going back there somewhere in a drop-down box. definitely mounting on the frame somewhere out of sight.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 06-28-2007, 11:05 AM   #5
speedybreezy
Brian ...
ive seen several on the frame with a drop down box. and that is probably what ill end up doing on mine!
speedybreezy is offline   Reply With Quote
Old 06-28-2007, 11:28 AM   #6
CAL 58 GMC
CAL 58 GMC's Avatar
I used the dropped box, it works great! Mine came from CCP. From the picture you posted it looks like you have a nice truck. Could you post a few more pictures?
CAL 58 GMC is offline   Reply With Quote
Old 06-28-2007, 11:57 AM   #7
mcarrel
Thanks for all the input guys! Just what I was looking for I especially like the CPP drop out box. I looked it up on there website. It is a little pricey seems I always have more time then $$$$$. Thinking how I might make my own? I have some pictures on a website here since you asked
http://www.tagworld.com/azmark
I am not very good at taking enough pics if there is something you want to see just let me know. Thank again
Mark
57 Chevy 3200 now a 3100 (frame shortened)
58 front clip
Front IFS Chubby Chassis w power steering
Rear 4-link from CPP w/Ford 8.8 limited slip disc brakes
350 SBC .060 over
89 700r4 trans
TPI off 86 IROC
Old 06-28-2007, 12:00 PM   #8
texascowboy593
texascowboy593's Avatar
Mine's from CPP as well. Not too hard to access it from there...
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 06-29-2007, 02:16 PM   #9
mcarrel
CAL 58 thanks for the pic it looks great. I had one thought where will your exhaust be. I am thinking you might run it out the side in front of the battery or it looks like it would be very close to the battery box????
I read thru your project thread and saw you did in fact run your exhaust past the battery. I also saw (like I have) it is very close to your brake booster and mst cylinder. Was therre ever any concerns about heat problems with either of these?
I have block hugger headers but like the looks of the ones you used where did you get them?
Old 06-30-2007, 06:48 AM   #10
pgf545
pgf545's Avatar
Mark, We just got one of the drop boxes from CPP. It is really simple and I would think you could fab up something.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
